Rattling noise engine
Started by Muroman, 29 April 2017, 06:24:03
Muroman
Hey,
So the engine is rattling or I think it's water pump, what about you? You got 100% info?
Here is a video of the sound and this video isn't mine but sounds just like the same. (The X sound)
I hope the owner or anybody else doesn't mind me linking this video here.
https://www.youtube.com/watch?v=Z_E0TowDBMM
Mika
Driving: Vectra - 2002 - 2.2 "GTS" - Manual
Old: Omega - 1999 - MV6 - Automatic
Old: Omega - 1995 - MV6 - Manual
baggers
The higher pitch noise makes it sound more like the idle roller (top left).
baggers
Very simple test, loosen serpentine belt then then spin it  :y
Quote from: baggers on 30 April 2017, 12:42:07
+1 Applies to all the pulleys you can see :y
Waterpump play will be self evident, likewise worn bearings...
Muroman
Sound only comes as engine cold. Without the belt it doesn't make any sound. The idler is new and when I heard it was bad you could hear it clearly being it but this is different.
Any of the pulleys won't make any noise when just trying to roll them with hand...
How you recognise the waterpump failure?
frostbite
check the roller above the alternator
e46 325i se - 1.8vvti avensis liftback
baggers
Maybe the air-con plates catching.
Quote from: Muroman on 01 May 2017, 16:03:03
With belt off, spin them by hand and feel for any roughness.  Also rock them top to bottom to feel for any bearing play, also worth checking no pully bolts loose  ;)  This applies to waterpump too
HTH
