Help with CCRT2008 needed.
Started by mantaray, 04 May 2017, 18:28:45
mantaray
My car currently has a CCRT2008 radio fitted, but the CD player is not working. I have had a look through the Maintenance Guides and got hold of a CCR2006 unit.
The Maintenance Guides says :
But what about the security code / NCDx pairing?
Fear not! The element that the coding / pairing requires will be swapped so you will not have to decode or de-pair/pair the units to effect the repair and in the case of the CCR2006, you will simply have to re-enter your code when you return the head unit to the car.
My question is, do I need to change the circuit board over, or will the CCR2006 CD player just plug and play?
Thanks for any help.
2.6 CDX Auto Estate,
71 Opel Manta A Series 2.5 V6
zirk
Assuming you have a mechanical problem, then by retaining your original ccrt board for the CD side of things you should be ok.
Forget the NCDC range for now tbey are coded differently.
