BMW E39 Front Arms
Started by Sir Tigger KC, 06 May 2017, 08:24:43
So I'm getting the familiar judder when braking on my 99 BMW 530d and think its the front suspension arm bushes have worn.  :-\
I can get a set of front arms for about £90 or a set of front poly bushes for £55.
Anyone here know whether these react well to polybushing like the Omega or should I fit new complate arms?  ???
TIA!  :y
JasonH
The E60 is a lot better with polybushes, so I suspect the E39 will be too.
The polybushes were a real pig to get in though.
Fraggles Rock
Fitted new arms to mine. Straightforward enough, but be mindful of not pressing the support bushes from the hub carrier...
Personally I would fit polys to new arms if you're that way inclined... They're aluminium and soft as soap compared to Omega arms. ;)
I bought cheap arms from eBay - a complete set for a similar price to that (all four arms, plus TREs) for the E64..
The bushes delaminated after about ~1500 miles.
It now has a set of Lemforder arms - £90 each.
Poly the originals or buy decent, I'd say..
Polybushing the originals was what I first had in mind, but then given the arms are aluminium rather than steel, I wondered if that was a good idea?  :-\
I don't want the arm to snap!  :o  ;D
I've seen those cheap arm kits on ebay from Dr G's favourite German factor?  I assumed they're made of cheese to be honest!  ::)
You can get Meyle HD arms for these which have the 4 year warranty
Quote from: Sir Tigger QC on 08 May 2017, 10:50:41
No prizes for guessing where mine came from... Seem to be solid enough, done about a thousand miles on them so far and no grumbles. Got the track rods and droplinks included set. That said I only replaced them due to the wheel arch liner cutting a notch in one arm. Handling is obviously a little tighter due to fresh bushes though.
The other thing with poly bushing it, front end kit is around £170 :-\
I had a CBA moment earlier and booked it in.....  :o  :-X  :-[  ;D
Quote from: Sir Tigger QC on 08 May 2017, 16:28:27
Squeak said the mouse ;D
Quote from: Doctor Gollum on 08 May 2017, 14:26:15
Priced up complete front and rear poly set for the black cat. £680. OUCH!!
Fraggles Rock
Quote from: TheBoy on 08 May 2017, 18:59:16
E39 is nearer £800 if you do all of them... suffice to say, I didn't bother ::)
No warranty Jaime?  Just had my fronts replaced on my cat due to slight splitting FOC  ;)
Quote from: dbug on 09 May 2017, 00:09:07
Its a silly warranty, won't cover wear and tear, and bushes are a service item really.
Personally, I refused to pay for the warranty, so I didn't pay for it. But they included it anyway.
Also, I don't want any mongrels touching the thing, only people I trust.  So dealer/specialist will only change oil annually for the stamp...  ...*IF* I decide to keep up "official" history, which I might not, as its a keeper. Next owner might well be scrapyard ;)
Quote from: TheBoy on 09 May 2017, 16:46:53
I'm surprised you did not use the forum resident car dealer?
