Show me yours.........headlight restore
Started by Webby the Bear, 07 May 2017, 19:32:09
Webby the Bear
Today I spent a good two hours restoring my headlights. As per a thread a while ago I had tried t-cut on someone's suggestion and I was thinking I was going to have to shell out for new ones. Well I got some vouchers from work and decided to spend them at Halfords for a proper kit.
This is the one I bought...
T'was a last ditch effort prior to being parted with my hard earned for a set of new ones.
Well I'm pleased to say it's worked  :)
Here's a pic of my OS headlight...
Now I will note that they are not perfect. But from the yellow horrid mess they were they are good enough for me. So I also did my fog lights too  :)
So I know some of you have done this. Can u put up some pics of your results so I've got a basis for comparison?
RIP Paul Lovejoy
Webby the Bear
Ps if I ever have to do this again I'll simply buy the 3 stages of paper (800, 1500 and 3000) and finish off with a polish  :y
RIP Paul Lovejoy
Quote from: Webby the Bear on 07 May 2017, 19:33:57
I hate to say it, but I told you so! 1000, 1200grit wet&dry followed by G3 polish is all I use:
from
to
in about 10 minutes
Webby the Bear
Nice one nick. And yes you were right  :y
I redid mine 3 times expecting each time to get better. It didn't  ;D but it did a good job from the off. I suppose the key is to spend as much time and effort as possible with the 800 (or 1000) to get all the proper crud off.  :-\
RIP Paul Lovejoy
korum
I had mine done by a local bloke of facebook for £25 and did a good job
You saw mine Webby, using a (well used!) 3M kit. Sadly, I didn't get photos. But as you know, results similar to korum's above, from cloudy to crystal clear in the time it took for 3 DeWalt batteries to go flat :y
Not sure if its just photo quality, but yours and Nick W's don't look crystal clear to me.
Webby the Bear
Yeah I remember thinking yours came up sweet.  :y
My headlight situ was/is identical to Korums pics. Yellow as pissy snow. And clear, but not perfect, after  :y
RIP Paul Lovejoy
