Author Topic: Head Unit / Canbus / Steering Wheel Controls Question.  (Read 3748 times)
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
HU and SW Controls, does it go via the Canbus or is it controlled directly?
In other words if I pull out a HU and power it up on the Bench will it work with a removed Steering Wheel?
Re: Head Unit / Canbus / Steering Wheel Controls Question.
« Reply #1 on: 08 May 2017, 15:24:51 »
Should work I would have thought  :-\
« Reply #2 on: 08 May 2017, 15:51:32 »
Yep. Done it myself Chris
zirk
  • Epping Forest
« Reply #3 on: 08 May 2017, 16:02:14 »
Ok, thanks Rob, next question as not got this far yet, is, is the loom from S Wheel to HU detachable easily, or is it tied up with other stuff behind the dash, or is just best to make one up some how.
« Reply #4 on: 08 May 2017, 16:06:46 »
Think it runs through the squib with the airbag and horn loom...
Making a loom up to connect the wheel plug with the head unit one ought to suffice. Dash loom has no end of shite tied up in it ::)
zirk
  • Epping Forest
« Reply #5 on: 08 May 2017, 16:11:55 »
Ok thanks,
So guessing next step would be to get Pin Out info or wiring diagram, anyone?
« Reply #6 on: 08 May 2017, 16:35:21 »
Pre facelift then Haynes... Later, then ring :y
« Reply #7 on: 08 May 2017, 19:06:11 »
No CAN between Omega HU and steering wheel.  Its a simple 2 wire circuit with switches presenting different resistance depending on which pressed.
Running on bench without switches will, at worse, store a code about remote buttons disconnected.  Like others, I used to do this frequently.
zirk
  • Epping Forest
« Reply #8 on: 08 May 2017, 20:04:22 »
Ah Ok, so uses resistive pad values depending on which buttons are pressed, well a pair of wires makes its easier to wire up, so in theory as long as the S Wheel is connected before power up the HU, should work fine and ignore any previous codes about no S Wheel buttons connected.
