Jaguar S-type V8 4.2 R
Started by Lagondanet, 10 May 2017, 11:03:41
Lagondanet
Anyone care to share their views on this model. 1997-2008? Supercharged?
I seem to have a hankering.
Viral_Jim
Engine is generally robust, has been in plenty of things and uses established (read ancient) technology. The 4.0 v8s had an issue with losing the Nikasil lining off the bores, and with timing chain tensioners. However this didn't affect 4.2's and iirc all R's are 4.2. Also, it's generally accepted that the ones that are still running will either have recon'd engines (usually under warranty) or the liners were good from the factory.
As for the car, papa '944 ran a 3.0v6 for years, (from 25k to around 140k) generally reliable thing, facelift cars (around 2002 and denoted by an electronic handbrake) are a significant improvement. Changes to electronics improved reliability and pre facelifts go through suspension components as consumables. Early ones did suffer rusty sills (under plastic covers), but not as badly as x-types. If I were buying one, I'd have the sill covers off first. As with a lot of Jags (past and present) random electrical problems are often caused by a battery that's still functioning but past its prime. Oh and check the battery, it's in the boot iirc and can rot out the floor if it leaks ::)
Generally they have a reputation for being a handful in the wet and fuel consumption is around 14-27 for the v8 depending on the weight of your right foot.
Ford era, not a true Jag I don't think. All other versions I would not be interested in one bit, but the supercharged lump could make it interesting.
However, I'd much prefer an XF-R  :)
Viral_Jim
Quote from: tunnie on 10 May 2017, 11:21:07
True, it's why most of them...um... worked ;D
Full Ford ownership was 1999 onwards, unlikely to be a lot of Ford influence on the designs at that stage (given car design is around a 5-7 year process), may well be some Ford parts.
Quote from: Fuse 19 on 10 May 2017, 11:39:55
Stand corrected... I thought it was some American/Ford hybrid.  :-\
henryd
#6
Quote from: tunnie on 10 May 2017, 11:58:47
I thought the S type ran a Lincoln/Ford thunderbird running gear albeit modified
edit, yes it did  https://en.wikipedia.org/wiki/Jaguar_S-Type
other rides
omegod
Wasn't Elite Pete running a V8 S type?
henryd
Quote from: omegod on 10 May 2017, 12:31:52
I think he still is :y
other rides
Quote from: henryd on 10 May 2017, 14:56:58
That's a good sign :y he was never one to keep an Omega intact for any length of time ::)
henryd
I had a 3.0 V6 S type in for the day a few weeks back and was quite impressed with it,250 bhp so no slouch either :y
other rides
btc
I ran one for almost a year without any issues did around 9000 miles averaged 22 mpg comfy and quick but can have a wayward back end in the wet only sold as my back is getting bad and I had trouble getting in and out  :y
The ZF sourced 6 speed auto from around that era can be unreliable. Other than that, corrosion and niggly electrical faults are the biggest issues normally.
Lagondanet
Quote from: Elite Pete on 10 May 2017, 20:28:43
Yep :y
And...your views?
or maybe similar era XJR V8 supercharged?  Compare?
Thanks for your opinions/advice.
