2003 N/S/F Door lock actuator problem
Started by Andy A, 11 May 2017, 10:40:19
Andy A
2003 N/S/F Door lock actuator suddenly stopped working. I was under the impression that it starts to play up before dying. Is this correct or could it be a broken door wire?
Thanks
Could be one of a few things...
Worth taking the door card off and checking the latch mechanism, linkages and that the solenoid is still plugged in :y
If you have a spare, then you might as well swap it out to check it :y
Andy A
Don't have a spare Al, will take the door pannel off and have a look. Did look on Ebay for one but couldn't see any.
Do you know if all the door actuators are interchangeable?
Fronts are the same and rears are the same, but ne'er the twain shall meet ;)
omegod
About 15mins to solder in new switch if you remove old solenoid :y
Shackeng
Quote from: TheBoy on 11 May 2017, 18:25:09
Its amazing how TB's times are always 1 tenth of the actual time you take. Yes, it's only 15 mins to solder, but considerably more to dismantle the actuator gently to avoid damage. Nevertheless, it is a comparatively simple repair. ::) :y
neil74
As has been said it's all easy enough once you get the parts out of the door. it's just getting them out is a fiddly pain in the arse of a job as theres not much room to get your hands in..
Magwheels
Takes me about half hour start to finish. Done it so many times now, about £1.35 each last time I got some off RS.
Only seems to be the fronts that play up!!
Quote from: Shackeng on 11 May 2017, 18:48:02
Remove boot, unclip loop. Punch out 2 pins. Separate black casing from white base (fiddly, but there is a knack, takes seconds). Sip tea, eat digestive. Less than a minute.
Desolder 3 connectors of switch, including a resistor. Switch falls out. Clip new switch in place, solder in, remembering to do resistor. Reassemble into black casing, and clip in place. Put loop and boot back on, knock 2 pins back in place. Sip more tea. Less than 5 mins.
Sit with a smug look knowing you've saved a small fortune, whilst finishing tea. 5 mins
All with help of Kevin Wood's excellent, clear guide :y
The hard, time consuming bits are removing the motor from door (15 mins if top of doorcard doesn't become detached), and about 25 mins to refit.
Personally, I always have a spare, so I can do the doorcard off, replace motor, doorcard on in one hit. Then refurb old one, and keep it for next time. There WILL be a next time with an Omega (not that Jag ones seem any better :()
Quote from: Magwheels on 11 May 2017, 19:41:56
Like many jobs, takes longer first time, as even with the best guide, you're still double checking what needs to happen next. But 1hr start to finish should about right, including removing and refitting, once you've done it a few times :y
Had a few rears fail, but always just replaced with known good spare, never took one apart.
Andy A
Do you have the RS part number?
Magwheels
Quote from: Andy A on 12 May 2017, 16:07:04
RS Stock No. 290-0463
Andy A
Quote from: Magwheels on 12 May 2017, 18:23:00
Cheers. Just ordered some to keep handy. :y
Andy A
Thanks all for your help.  :y It was a bad connection. Problem now fixed.  :)  :y
