technology driving me mad!
Started by Varche, 11 May 2017, 11:38:57
Varche
My Spanish landline went faulty. I reported it via a text from my mobile. They came and repaired it.
Now the problem. They have an automated service that dials your repaired line and all you have to do is pulse one for satisfied or two for dissatisfied.  When I pulse 1 it doesn't act on it. I have had this before on other peoples, including UK automated services and yet the one button works for dialling numbers including a one. How can that be???
As to the machine, I reckon I have had 50 calls or more in the last 24 hours. A lot unanswered as it only rings 3 times. I wonder what the algorithym is for stopping trying to get a customer response. ;D
I think your landline has gone faulty. :D
Mister Rog
Strange.
I never have any problems with my smoke signals and carrier pigeons
"The desire to be a politician should bar you for life from ever becoming one." Billy Connolly
Do you hear a tone when you press the number buttons?
I'm just wondering if your phone is using pulse dialling instead of DTMF tones?
Does it have a switch on it somewhere to select between "P" and "T"?
Varche
No switch i can see. Havent tried 2 as that would be wrong. I am happy with repair service plus i dare say they would follow up why i wasnt happy.
Cant see a switch. Might be a software setting
Instrument is a Siemens Gigaset AL27H but havent got a manual for it. Yes there is a tone when you press any digit.
Quote from: Varche on 11 May 2017, 12:23:51
[/quote
Precisely. You are happy but they could then advise you as to why you pressing one doesn't work. It might also be that 2 doesn't work either, in which case you're stuffed :D
I'd be surprised if anything that modern didn't default to tone dialling, but it might be worth checking if there's a setting in a  menu somewhere, as it might be possible to configure it to use pulse and, as it's DECT, the tone might be generated locally in the handset. :-\
zirk
Disconnect the two landline wires that are connected to the Phone, tap them together once, wait about 650ms then tap them together twice, then twist the 2 wires together and leave it like that.
That should sort any incoming and outgoing call problems you are having.  ;D
