Random non starting
Started by Pmacca2000, 23 May 2017, 21:29:29
Pmacca2000
I've just had all the leads and coil pack replaced on my V6, with increasing regularity it struggles to start. When this happens it takes about 4 goes before she fires.
Is this a fuel pump issue or injections? She cranks over ok
Pmacca, living the dream since 1995
zirk
#1
Random or Non Starts on the V6 are normally down to the Crank Sensor.
15 min job to replace once under the car, fit Genuine GM, cheap aftermarket CS wont last 5 mins before causing the same issues.
flymofred
Yup I had same symptoms, new crank sensor its been fine ever since
