I`m tempted
Started by 78bex, 26 May 2017, 22:39:25
78bex
So main stealer wants to fit a new engine  ::) what do they know :P
Low compression & a lumpy idle, burnt valves  :-\
http://www.ebay.co.uk/itm/2009-VW-GOLF-GT-TSI-/272682696585?hash=item3f7d27bf89:g:MxEAAOSwq1JZIy3~
Viral_Jim
Been running lean? Question is why.
Recon head is easy enough to source, or strip it and have it recon'd. But then what's to stop it happening again.
henryd
Someone I know who works for VW has mentioned this issue,it happens quite often and the only fix they will do is replace the motor :-X
other rides
Quote from: henryd on 27 May 2017, 09:39:48
I guess as a garage, its the only option, in case of piston and other damage if its run lean.  Otherwise, comebacks could get expensive.
ronnyd
I must say that it is refreshing to see such an open and honest advert. 8)
It's an eight year old golf that's done over 100,000 miles and has a major engine problem. Don't be seduced by its appearance.
Lincs Robert
Quote from: STEMO on 27 May 2017, 11:44:09
+1
henryd
Quote from: ronnyd on 27 May 2017, 11:20:38
other rides
henryd
The problem is with oil consumption being too high on long life servicing and the lack of any warning that the oil is low,first warning thats visible is the oil pressure warning and its too late for the engine by then :'(
other rides
Quote from: henryd on 27 May 2017, 13:39:52
Had they bothered to Please read the manual, they would see that Vw consider normal oil consumption to be in the order of a litre every 1000KM... ::)
Lincs Robert
To quote that well known marketing line:
"If only everything in life was as reliable as a Volkswagen"  :-X
henryd
Quote from: Doctor Gollum on 27 May 2017, 14:19:48
True, but your average Joe doesn't open the bonnet between services :(
other rides
Quote from: henryd on 27 May 2017, 14:57:05
Or Please read the manual ::)
Quote from: Doctor Gollum on 27 May 2017, 15:41:38
Or except the VAG group have been churning out some right dogs over the past few years, esp in the engine department.
tidla
TSI model, Is that the petrol direct injection engine with a turbo?
