Wanted, Fuel Return Hose from Injector Rail.
Started by zirk, 06 June 2017, 20:56:01
zirk
Not sure if its the same as the Fuel feed Pipe to the Injector Rail, but the Return Pipe will do for me as I can get to it easerly without ripping Air flow Pipes off on a 2.2.
Pic below (Not a real Pic) may not need the whole pipe, if its been cut, just need the screw in part with enough rubber hose that I can bend and attach another hose to it. :y
omegod
Should have one on the 2.2 I'm breaking, will check tomorrow  :y
zirk
Quote from: omegod on 06 June 2017, 22:12:57
Ok Thanks, its the one towards the front of the car, although if your breaking it, I may buy both of them of you.
