Author Topic: aircon  (Read 5971 times)
lesask
  • london
    • omega 2.6cdx
aircon
« on: 09 June 2017, 12:33:51 »
Ok, 2.6 cdx. the aircon has stopped. My garage has called to say that the high pressure valve is knackered and it lives in this pipe and the whole pipe needs to be replaced. The pipe will be several hundred pounds plus the labour plus the regas, so this is not worth it. However is there any experts here who can advise me to complete this job a lot cheaper? could I get a second hand part and replace it myself then get the garage to regas? any suggestions out there? or just leave it. Many thanks, Leslie
Re: aircon
« Reply #1 on: 09 June 2017, 12:47:38 »
Garage is talking rubbish, I'm sure valve itself can be replaced?
Re: aircon
« Reply #2 on: 09 June 2017, 12:52:11 »
It can. For less than two pints...
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
Re: aircon
« Reply #3 on: 09 June 2017, 13:03:25 »
Show them the very helpful guide in the relevant section :).
http://www.omegaowners.com/forum/index.php?topic=124057.0
Hoof'land storeman.
lesask
  • london
    • omega 2.6cdx
Re: aircon
« Reply #4 on: 09 June 2017, 13:41:28 »
many thanks, its true the garage hasnt actually replaced these parts before but he clearly showed me the problem, that is the lower down pipe that has one of these things that lives within the pipe, it looks like it screws off but it doesnt, it is a fixed unit and apparently because of this that pipe section needs replacing, through vauxhall this pipe is obsolete and even if he could get the pipe it would cost a lot of money, so ive got the car back. Im thinking of getting a second hand pipe section, replace that bit and then take it back to regas. Does this sound ok? he has sucked out all the old gas and any moisture so its safe for me to work on it. If any of you good chaps live within a 100 miles or so of se london and feels good to fix it then im more than happy to drop a good sum. Many thanks. Les.
Re: aircon
« Reply #5 on: 09 June 2017, 14:06:28 »
It definitely unscrews. If you can get the valve and the car down to Gatwick towards the end of next week I might be able to do it...
When I say might, I mean having the time, not the ability... have changed several  :y
Nick W is nearer if he has the time... his hours are a bit more 'normal' iirc ;)
lesask
  • london
    • omega 2.6cdx
Re: aircon
« Reply #6 on: 09 June 2017, 14:30:34 »
arr brilliant sir, ok ive looked at the exact problem and i can see that it looks like the top bit does unscrew but ive tried and tried with everything in my arsenal and I cannot unscrew it at all. This is what my garage said, he said he cannot do it, hence to replace the pipe complete but I dont want to give up yet on this valve. Ive sprayed it with penetrate spray but i think that is just a token gesture. Im thinking of cutting across the top of it to create a slot for a wide screw driver. the 'flat sections' do not accept a spanner and is rounding off as im working on it so im giving up for now. I try again on sunday to get it off. If I just cant do it then if you dont mind id be happy to drive down to Gatwick, i can do that in an hour or less. My Omega is a very nice drive and clean and my garage says that so I want to keep it as long as possible. Many thanks. Leslie
Figureman52
  • Nottingham
    • 2.6 CD Saloon
Re: aircon
« Reply #7 on: 09 June 2017, 14:38:00 »
Did mine last year, used a pair of mole grips on the valve as a regular spanner doesn't fit.
Part no. 13277003, obtained from dealer for £5.50.
lesask
  • london
    • omega 2.6cdx
Re: aircon
« Reply #8 on: 09 June 2017, 14:47:54 »
many thanks. will attack this again,
Re: aircon
« Reply #9 on: 09 June 2017, 15:09:27 »
Did mine last year, used a pair of mole grips on the valve as a regular doesn't fit.
It does ...... 15mm socket fits. It's  a snug fit, but does fit. 17mm IIRC to hold the block it screws into other wise it'll shear off the pipe (not that any of our admin have ever done that  ;))
biggriffin
Re: aircon
« Reply #10 on: 09 June 2017, 15:51:27 »
Post #3.
Or contact Serek sos automotive, he would fit new valve, and regas. Highly recommended  :y
« Last Edit: 09 June 2017, 15:53:21 by biggriffin »
Hoof'land storeman.
Re: aircon
« Reply #11 on: 09 June 2017, 15:52:02 »
Nothing to see here, move along now ::)
DrAndyB
  • The Wirral / Cheshire
    • 2.5 V6 CDX Manual (MFL)
Re: aircon
« Reply #12 on: 10 June 2017, 12:39:01 »
:y Sure can be replaced.  Did my High Pressure valve a couple of years ago and also replaced valve core in the Low Pressure Value (standard Schrader core from memory)   :y
Garage did it when they did the A/C Refresh as needs doing of course when all depressurised and refrigerant all sucked out. so worth getting both done just to be sure.
Re: aircon
« Reply #13 on: 10 June 2017, 16:18:55 »
This particular garage is not unique though when they suggest that the whole pipe needs replacing. I was told exactly the same thing by an air/con specialist & plenty of others here have been told the same thing.
This is the valve on its own
jimbo125
  • Camberley
    • Vauxhall Omega 2.5V6CDI
Re: aircon
« Reply #14 on: 11 June 2017, 01:11:20 »
Vx have them cheap as chips and easy to replace :y
2.5V6 Had it since 2002, what a beast, worth the time and effort to keep it road worthy. Vauxhall bring them back!!! Laser timing kit for OOF member hire
