LPG kit and loads of parts
Started by omegod, 16 June 2017, 17:33:24
omegod
LPG kit off 4 cyl, 70 litre Stako tank, Landi Renzo front end vapourizer kit with full wiring loom  £100
Some bits include post, some don't,
Good scuttle £15
Starter motor £15
120 amp Bosch alternator £20
100 amp Bosch alternator £20
2.2 Pet Master Cylinder     £15
Estate Fuel pump assembly £25
Saloon fuel pump assembly £25
Pair of good front calipers £20
Rear solid disc calipers £20
Set of facelift estate door trims some in primer, some Polar sea blue £20
Mint headlight switch £15
Estate load liner £10 ( pick up only )
Front door solenoids £20
DTI cat back exhaust in good nic, £20
2.2 Pet cat back exhaust near new £30
2.2 Pet downpipe and cat  £40
2.5 ecu set with 2 chips, carpass codes £40
2.2 ecu set with 2 chips  carpass codes  £50
Polar sea blue MFL door mirrors £15 each
Wiper mechanisms £25
2.2 auto ABS ECU £20
Z147 facelift doors,boot, wings and bumpers, door strips in good nic £ask
If it's not listed I've prob got it so ask
CCRT700 phillips stereo and Blaupunkt CDC2 CD multichanger, believed working and with both codes, main knob on stereo is a bit chewed up but good for spares etc
Worth posting date stamped on tank, as it might not be possible getting a car LPG registered if the tank is past its 10yr date....
frostbite
Which front calipers do you have?
e46 325i se - 1.8vvti avensis liftback
omegod
Quote from: frostbite on 21 June 2017, 08:49:48
I have v6 and 2.2 ones, I think they are the same though
frostbite
Cool, a deal has been struck
cam.in.head
i have a wanted ad up so i assume you wont have these but i am after some dark grey cd/cdx saloon seats.
omegod
Quote from: cam.in.head on 21 June 2017, 17:04:49
I do have a dark grey facelift CD interior in good order, someone from another forum wanted the front seats but is dragging their feet so if you're quick......
cam.in.head
steve6367
Quote from: omegod on 16 June 2017, 17:33:24
Good scuttle £15
Starter motor £15
Is it original GM do you know?
omegod
Looks original but no codes at all so I'm assuming the casing has done the usual falling off routine otherwise I'd have weighed it in, can get some pics for you
