My lad is revising for further maths
Started by STEMO, 18 June 2017, 14:48:32
I went up to his room to do something and he told me that he was having trouble getting z tests to work out. 'Keep at it' I said, 'you'll get there'.
So I came down and thought I'd have a quick look to see if I could help. I mean, it's only numbers. So I found this:
A Z-test is any statistical test for which the distribution of the test statistic under the null hypothesis can be approximated by a normal distribution. Because of the central limit theorem, many test statistics are approximately normally distributed for large samples. For each significance level, the Z-test has a single critical value (for example, 1.96 for 5% two tailed) which makes it more convenient than the Student's t-test which has separate critical values for each sample size. Therefore, many statistical tests can be conveniently performed as approximate Z-tests if the sample size is large or the population variance known. If the population variance is unknown (and therefore has to be estimated from the sample itself) and the sample size is not large (n < 30), the Student's t-test may be more appropriate.
If T is a statistic that is approximately normally distributed under the null hypothesis, the next step in performing a Z-test is to estimate the expected value θ of T under the null hypothesis, and then obtain an estimate s of the standard deviation of T. After that the standard score Z = (T − θ) / s is calculated, from which one-tailed and two-tailed p-values can be calculated as Φ(−Z) (for upper-tailed tests), Φ(Z) (for lower-tailed tests) and 2Φ(−|Z|) (for two-tailed tests) where Φ is the standard normal cumulative distribution function.
I think I'll leave him to it  ;D
ronnyd
Viral_Jim
It all got a bit hazy after "I went"... ???
;D
ronnyd
Does that stuff have any relevance in the real world?  ???
Quote from: ronnyd on 18 June 2017, 16:08:13
Yup. Used for statistically grading samples of anything... grains of rice/rivets/likelihood of resisting a very specific form of cancer based on genetic origin and whether you eat carrots or not/likelihood of any given grade of insulation panel resisting burning below/above any given temperature... which reminds me...
TD
Its easy, let me explain simply.....
For example..
Each apple weighs 0.25lbs and price of apples is £1.50/lb.
How much are 1kg of bananas?
See easy  ::) ;D
Quote from: TD on 18 June 2017, 17:00:03
For example..
See easy  ::) ;D
Statically speaking... :D
BazaJT
I understood every last word of that                          oh no wait a minute that should have been I understood the last word ;D ;D ;D
Viral_Jim
Does the lad have any idea what he wants to do as a career ste? He seems like a helluva bright chap!
Quote from: jimmy944 on 18 June 2017, 21:45:24
He wants to follow in mummy's footsteps....teaching. I've got about 4 years to convince him of the error of his ways.
Viral_Jim
Ha!
You could talk to him about the actuarial profession, and the joys of a 6 figure salary  ;D
Quote from: jimmy944 on 18 June 2017, 21:54:04
Ha!
AI will be taking care of all that soon.  :P  ;D
A Z test is just a means of getting an indication if a set of results is valid or not
Whatever happened to......"lf Johnny has two apples and he gives one apple to Jilly (for a quick feel) how many apples and what percentage of the original apples does randy Johnny have left"
Answer......one apple and 50%.
Kids stuff. :)
On his mother's side. :)
