Rear brake kit
Started by frostbite, 24 June 2017, 17:14:18
frostbite
I just recieved this morning probably the oldest best deal ever from ebay, I think early 90s?
It says its not for the 3.0 carlton or the 24v senator, did those have vented rears?
for a massive £9 I got
e46 325i se - 1.8vvti avensis liftback
Not a bargain. But equally not a bad deal.  ;)
Yes. Equally only the pads are of any use for the 2.6/3.2 Omega :y
omega2018
#2
good deal for you, bad deal maybe for the people of Skelmersdale http://www.asbestosadvicehelpline.com/is-asbestos-still-used-in-car-brake-pads/
frostbite
Ill have that fresh burning brake smell mmmmmmm makes me feel sick when ever I smell a burn clutch, like raw sewage
plenty of derty dervs driving about that are possibly worse than these pads ever will be
omega2018
yes but worse if they're using pads from early 1990s before asbestos was banned in brake pads.
Bigron
If they do contain asbestos, they will be better anchors and your discs can be harder too, with consequent longer life; if they were contemporaneous, they will be.
Unless you wilfully breathe any of the dust, you will be fine. In your one-off circumstances, it's a non-issue.
Ron.
£10 delivered gets genuine OE GM ones for solid discs :)
frostbite
The oe pads may be a tenner but I remember getting the pins and spring clips seperate, they cost more than the mintex kit
Quote from: frostbite on 24 June 2017, 21:38:28
OE rear pads come with fitting kit (ie, pins and rattle spring) :y
Migv6 le Frog Fan
Quote from: Bigron on 24 June 2017, 20:30:19
Ron.
Istr asbestos pads give off less dust too ? Cant see any good reason why they banned them tbh.  :D ;D
Bigron
Panic, Albs! Over-reaction, and the need to be "seen to be doing something" - like the specious argument regarding lead in petrol. Neither is harmful if proper caution is observed, but once again we suffer due to the woeful ignorance of our politicians..... >:(
Ron.
Having a friend who died of mesothelioma, I do know why they banned it. It's really not a nice way to go, for the sake of brake disks that last a little longer.
Quote from: Kevin Wood on 25 June 2017, 10:51:19
Cannot argue with that...
Is it not now illegal to sell pads containing asbestos? I know that even on newer cars replacement pads contain warnings that parts already fitted may contain it and to therefore be mindful not to breathe brake dust in...
From an asbestos awareness course at work, blue asbestos is still widely used in the US.
Frostbite...
Read this...
http://www.hse.gov.uk/mvr/mechanical-repair/asbestos.htm
Then contact the supplier of your brakepads and demand a refund plus disposal costs.
Bigron
Kevin, I'm sad to hear about your friend and in no way did I want to harm your memory of him, but I do see your point and I am wrong.
I claimed that it was safe if handled carefully, but in the ad hoc environment of a garage - commercial or home - if it needs to be treated with that much care, it is right that it was banned. Sorry.  :(
Ron.
