Pages: 1 [2] 3  All   Go Down
Author Topic: V6 Exhaust questions  (Read 9736 times)
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
Re: V6 Exhaust questions
« Reply #15 on: 25 June 2017, 11:34:49 »
Just a thought about the doctor cutting a slot in the flange. Could you not take the slot passed the flange and cut through the bolt releasing the grip?
omega2018
    • MercCL500 Omega2.6ManElit
« Reply #16 on: 25 June 2017, 11:58:17 »
yes that would cut out the hammer bit
so DG you have a flange which bolts screw into, the bolts seize on and rather than simply drill them out you want to take a grinder to the flange, remove a large slot in each side,  bash out the bolts (as robson says why not simply keep going with the grinder and grind them away) and then try and fix on the new exhaust to the remains of the flange. which has been weakened with two large slots and is technically no longer a flange. two half flanges if you like.  have anyone ever seen a fitting designed with two half flanges instead of a flange?  does that tell you something?
« Reply #17 on: 25 June 2017, 12:14:02 »
Cut upto the bolt using a dremmel rather than an angle grinder. Then open the slot with a flat blade and tap the bolt out. Replace with a size smaller bolt, washers and lock nut.
Carefully slot the outer edge of the flange in to the bolt/stud, apply heat and smack it out with a suitably sized hammer.
On reassembly, use bolts and washers. Done :y
From experience, the flange on these aren't strong enough then going forward  :'(
Done on both my estates and neither had the exhaust fall off. Wouldn't have suggested it otherwise.  ;)
terry paget
  • Midsomer Norton Somerset
    • 3 Astras 2 Vectra
« Reply #18 on: 25 June 2017, 20:38:38 »
I think you misunderstod DocG. He suggested one cut for each bolt, in from the outside as far as the bolt, then prising open the flange slightly to allow the bolt to be bashed out. Robson suggested continuing the cut throught the blot as well, releasing it as 2 halves. Either way, enought flange remains to do the job.
« Reply #19 on: 25 June 2017, 20:39:58 »
He didn't misunderstand. Rather being deliberately obtuse :-X
omega2018
« Reply #20 on: 25 June 2017, 21:03:06 »
yes thats what I thought.  except the 'prising open the flange' bit which is new.  so you cut two slots into each flange, one for each bolt, thus considerably weakening the flange.  Then you prise open the weakened flange at the two weak points you have just created.
its genius  :D
i'm surprised DG didn't design for Vauxhall this is a big improvement on their original flange-with-two-threaded-holes design.  a flange with two dremel hewn slots, prised open with a  lever.  what could be stronger than that? :-X  on a system prone to massive temperatures and rust. ::)
« Reply #21 on: 25 June 2017, 21:05:14 »
Go fuct yourself.
« Reply #22 on: 25 June 2017, 21:40:11 »
OK, Doctor Gollum and migmog, you're both in the last chance saloon.  Grow up, FFS  >:(
« Reply #23 on: 25 June 2017, 21:42:04 »
If the notch bothers you, two minutes to weld it back up.
omega2018
« Reply #24 on: 25 June 2017, 21:52:10 »
so it's
dremel ;D cut flange, prise apart, hammer out bolt, prise back to original position, get welding kit out, weld up the 4 cuts you just made
v
carefully drill out bolts.
hmmm... ::)
« Reply #25 on: 25 June 2017, 21:59:58 »
I was talking to TB :-X
« Reply #26 on: 26 June 2017, 09:55:00 »
You have a plasma cutter, cut the bolts flush and use the cutter to blast a hole through the middle.
Then gently increase the hole size until the bolt remains fall out.
« Reply #27 on: 26 June 2017, 18:21:10 »
That thought had crossed my mind yesterday.
Would the ECUs need disconnecting, like when welding?
« Reply #28 on: 26 June 2017, 18:29:11 »
To nut and bolt it back together, do I use, say SS nuts and bolts, or BZP high tensile etc?
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #29 on: 26 June 2017, 18:41:31 »
Don't use stainless if you ever want to take it apart again. Buy good quality BZP from a proper fastener supplier, the four bolts and nuts you need will give change out of a quid.
Pages: 1 [2] 3  All   Go Up
