What should I use....
Started by Sir Tigger KC, 04 July 2017, 14:23:00
.... to clean the protective coating off of new brake discs?  ???  I have petrol and white spirits here.  Will they do?  :-\
TIA!  :y
Migv6 le Frog Fan
Normally brake cleaner, but I would imagine petrol will be fine. I think white spirit may ;eave a slighty oily residue ?
Viral_Jim
Think I used cellulose thinners last time, but only because I had them to hand. As an alternative I would imagine spray oven cleaner would do the job, designed to cut grease after all :)
Spray a bit of lubricating oil on them and report back.
This thread reminds me of when I was sixteeen. My friend owned a blue and brand new 1976 Suzuki AP50 sports moped which he loved with the exception of a front drum brake that would constantly squeal when applied.
Just for a joke myself and another friend said that Castrol LM grease liberally smeared over the front brake shoes would stop the annoying 'squealing'
Didn't think he'd actually give it a go but to be fair it did stop the squealing. :)
Quote from: Migv6 on 04 July 2017, 14:30:16
So does petrol.
A can of brake cleaner is only a couple of quid, and is probably 'best'
I use thinners.
Migv6 le Frog Fan
Quote from: Lord Sittapong Meerkat on 04 July 2017, 14:46:12
I did exactly the same to a bloke with a Honda CG 125 with a squealing front disc. He went through a hedge.  :-[ ;D
frostbite
carb cleaner can be used also, but evaporates quickly
e46 325i se - 1.8vvti avensis liftback
Mr Gav
Quote from: frostbite on 04 July 2017, 16:11:43
I think it the same stuff as brake cleaner TBH, I`ve always used either and as you say it evaporates very quickly  :y
frostbite
Similar stuff, I'm sure you cant use carb cleaner on friction lining because of the adhesive
Webby the Bear
Brake clean. Get it in a can. Or 5l tub and pump bottle.
RIP Paul Lovejoy
Webby the Bear
And while you're there get a tube of silicone paste for your slide pins.
and if you want to use something better than the shite copper slip get some Ceratec. Not sure if it's a Pagid own brand or their version of a type of grease called Ceratec lol but I've used this for special people's brakes (i.e. my car....every other fekker gets coppa jism😂) as it stays like jism as opposed to drying up.
RIP Paul Lovejoy
frostbite
I have 3 sachets and a tube of ceratec, its a mintex brand
deric3r
I've always used brake cleaner.
