Diff, how heavy ?
Started by omegod, 05 July 2017, 12:23:57
omegod
Random I know but estimated weight of a 2.2 Petrol Diff, prize for the nearest guess  ;D need to estimate postage before I have chance to remove the bugger
Migv6 le Frog Fan
Its a lot heavier than that. I weighed one years ago but cant remember the figure now. I would guess between 30 - 40kgs ?
zirk
I would say between 40 to 45 Kg, without fluid.
Both hands needed to fit, remove with jack / support assistance, once removed and in a Bag can easierly be carried with one hand, without arm falling off.
omegod
I'm thinking 25-30 kg from last time I lifted one, hoping to avoid needing a pallet for delivery as I have a tough plastic crate that may be strong enough
Quote from: omegod on 05 July 2017, 13:58:00
Pack it in snug though, otherwise first knock will crack the plastic :y
My sensible guess would be around the 25kg mark ;)
omegod
Quote from: Doctor Gollum on 05 July 2017, 14:26:32
That'll be a first  ;D  , yeah I'll pack it well.
terry paget
I guess about 35lbs, 16kilos. I the morning I will weight one.
Mr Gav
I would say 25Kg, manual box is around 50Kg  :y
omegod
And the answer is, 28.6 kg ! it's going on a pallet by the looks of it as there's more parts being added to the order
I didn't think it could be as heavy as 45Kg (as suggested in one post) - the XJ40 diffs are in that area and they're cast iron lumps.. I'm sure one of them is responsible for my hernia!
omegod
Quote from: aaronjb on 06 July 2017, 10:56:46
This one's responsible for me having a sore neck, on a plus side the diff mounts are in perfect condition so should garner a few quids  :y
