Climate Control High Pressure Service Valve
Started by John C, 08 July 2017, 15:53:59
John C
Hi there, can anyone tell me if the High Pressure Valve is part of the pipe or can it be removed/replaced. It's leaking.
Thanks for any help.
DrAndyB
Yes, HP valve can be replaced.  There is a guide somewhere on here, and there was a post a bit ago with Part numbers.
Part is cheap as chips at the Vauxhall Stealer  :y
Changed mine a few months ago  :y (obviously with AC drained and all nasties sucked out before refilled.
Maybe worth changing the LP valve at the same time - Standard Schrader valve core from memory.
John C
Dr. Andy,
Many, many thanks, I have all the information I need thanks to you.
Can't thank you enough'
Best Regards
John
Quote from: John C on 08 July 2017, 17:09:08
Dr. Andy,
Best Regards
John
You'd be surprised how many 'experts' will tell you the valve is integral to the pipe .....  ???
