VM router box v3 port forwarding
Started by minifreek, 11 August 2017, 16:26:06
minifreek
Does anyone know how to setup port forwarding on the newer V3 Superhub that VM supply please.
Iv recently had to have them come out to my VM box and the 'engineer' replaced my older box with the new V3 box, but now I can't get to setup port forwarding for remote viewing of CCTV
D.I.L.L.I.G.A.F...
Gaffers
Get a decent router like the linksys lrt214 and use the VM router in modem/pass-through mode.  Not only will you be able to setup PF and firewall rules better, but it will also do a fairly decent VPN which you can use to keep your web traffic safer when using public wifi. I also find this setup more stable than using the VM router on its own.
Its the main reason I wont touch sky broadband anymore as they use MER which makes setting up your own equipment a lot more difficult.  I would never trust the security of a supplier provided router on its own, not after what I have learnt in my current role :-X
Also the VM Superhub 3 is liable to fall over regularly, due to an as yet unfixed DoS problem, where even a simple portscan will kill it.
Get a decent router. All ISP supplied ones are shitter than shit.
Gaffers
Quote from: TheBoy on 12 August 2017, 09:02:13
Using your own router and switching the VM3 into passthrough mode stops this issue as all traffic is passed to the new router which is why you need a good one.  I am seriously impressed with the linksys, a bit pricey but worth it.
Depends on what you want out of them, I got early dibs on the newer Sky ones some time ago as a staff trial.
I've turned it on, stuck it in the cabinet and it's just worked. I think I've rebooted it once in last 6 months, that was due to a line issue not router problem.
Quote from: tunnie on 12 August 2017, 11:55:44
I ask for something that's secure, reliable and does what it claims it should.  All ISP provided freebies fall down on all 3, with the exception of some ISPs with locked down routers, which fail on the first 2, but not on the 3rd, simply because all features are locked out.
But what do you expect for free ;D
minifreek
Thanks for the advice on the router, I'll take a look at buying 1 in the near future...
I jumped on YT and thats solved my problem, so looks like its OK for now...
Problem I had was the old router needed restarting - no exxageration - 20 times in 1 day.....!!!!
I had to threaten to cancel my contract with VM to get them to come and change the router.... idiots...!!!
D.I.L.L.I.G.A.F...
