Help with a cooker....
Started by TD, 12 August 2017, 16:28:40
TD
Its a Belling FSE 60MF
One of the rings is either fully on or off (when turned off)
So, say you put the ring on position 1 it heats up read hot and stays like that.
Now I thought it was going to be the control knob and would be fairly easy to change.
So, I take the top off, pop the knob of the control off. Theres no visible screws to undo which I thought taking the knob off would reveal.
The switch is also tightly packed with other gubbins in the way.
Then I notice the heating element.....its this one
http://www.bellingspares.co.uk/cooker-oven/fse60mf-blk-444449576/ceramic-hotplate-element-single-1800w/product.pl?pid=1162876&path=600217&model_ref=3529439
That's looks like some sort of thermostat running across the top in a glass tube  :-\
So now I'm undecided, is the fault the control knob or the heating element  :-\
Any ideas chaps.......
No idea Dave, but I do like a good White Goods thread!  :y
We havn't had one for a while.  :)
#2
Ceramic hobs have a high temperature cut off thermostat to protect the glass - this is in addition to the control knob.
TD
Quote from: Andy H on 12 August 2017, 16:41:39
Ceramic hobs have a thermostat to protect the glass - this is in addition to the control knob.
So, your saying that is a thermostat on the heating element but nothing to do with the fault... :-\
Quote from: TD on 12 August 2017, 16:44:15
Yes
TD
Quote from: Andy H on 12 August 2017, 17:35:16
Yes
Ok thankyou  :y
I'll have another looksee tomorrow on how you get the control out.....canrt find anything online to help me tho  :(
TD
Quote from: Andy H on 12 August 2017, 20:24:11
This may not be the actual device but I think you need to replace one of these http://www.bellingspares.co.uk/cooker-oven/fse60mf-444449575/energy-regulator-mp-v01-svc/product.pl?pid=947593&path=600217&model_ref=1162552
I think that is the item I need....its how to get to screws holding it in I'm struggling with....looks like i'll have to take off all the knobs and remove the front panel somehow  :-\
Viral_Jim
In the back of this service manual (slightly different model designation but the structure looks identical to yours- different designation for different region maybe?) there is a circuit diagram and some exploded diagrams. Also a parts listing. Should be everything you need  :y
https://www.manualslib.com/manual/886003/Belling-Fse-60-Dop.html#manual
TD
Quote from: jimmy944 on 13 August 2017, 09:30:36
Thankyou, just what I needed, It is slightly different and I didn't have to remove the sides to get the glass top off as the manual says you have to. But it does show me to get the control cover off I need to remove the sides  :y :y :)
TD
Well I got there in the end.... :y
Can I give a Belling designer an award for something....  :-\
So its a halogen hob cooker.....whats the most likely thing to go wrong....ah yes! the control switches...
So we'll design it so to replace one of the switches....
You have to remove the top (fair enough)
Then you have to remove the sides to access the screws for the front panel
But we'll make it so you carnt take of the left side panel unless you remove the oven door
Then you have to take off all the knobs
Then unscrew the front panel to remove it
Then you can get to the screws to undo the switch!
There...that should stop anyone attempting DIY  >:(
Quote from: TD on 13 August 2017, 16:34:28
Didn't stop you  :)
Yes you should have just taken it to the tip and bought a new one!  ::)
Quote from: Sir Tigger QC on 14 August 2017, 09:00:26
I think they're about £600, those cookers...worth repairing.
Viral_Jim
Yup, we have a 2 oven rangemaster (came with the house, no way I'd pay the £1500 it cost!), fan unit in the oven died,
Only accessible from the back ::). Not easy considering it probably weighs more than my first car!
