Author Topic: Ford 1.6 Tdci fuel filter change  (Read 5641 times)
Lincs Robert
« on: 25 August 2017, 20:28:04 »
Hi,
I'm looking to change the fuel filter under the bonnet on the Mondeo. The filter is quite a large metal jobless and has a couple of click on connectors. Seems the system needs priming afterwards and Ford done have a priming pump - you have to use an external bulb, which I don't have.
Does anyone have experience of this, same as the 1.6 Hdi engine. Could I just turn the ignition on/off several times before starting?
Thanks - Rob
Re: Ford 1.6 Tdci fuel filter change
« Reply #1 on: 25 August 2017, 21:17:59 »
I think it'll self bleed Robert.  :y
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
« Reply #2 on: 25 August 2017, 22:24:19 »
Hi,
Thanks - Rob
If you don't have the primer bulb on top of the engine under the tdci stamped cover then its probably got a lift pump intank so as already  said ignition on off a few times
Hold up!
If it's later model with metal filter then the top cover has a primer button built in (the top is reused on the metal filater type)
« Last Edit: 25 August 2017, 22:26:44 by henryd »
other rides
henryd
  • west cornwall
« Reply #3 on: 25 August 2017, 22:39:15 »
Having had a Google its seems the ford type filter top doesnt have the primer button that its cousins from frogland do so would suggest intank lift pump
other rides
« Reply #4 on: 26 August 2017, 09:55:56 »
Ignition on and you should just be able to make out the sound of the pump running, let it run until.it times out (30 seconds or so), repeat a few times.and the it should just start
TD
  • Swindon
    • Nowt!
« Reply #5 on: 26 August 2017, 17:09:48 »
I seem to recall, that when the fuel filter was changed on my 1.6 TD Mondeo.....the blokey that changed just cranked it over till it started.....tho he did have a booster pack on the battery whilst doing so......so no priming needed it seems  :y
and probably the advice of just turning the ignition on a few times would likely have to same effect  :y
« Reply #6 on: 26 August 2017, 17:24:35 »
He's a bloody Muppet then!
TD
  • Swindon
    • Nowt!
« Reply #7 on: 26 August 2017, 17:37:55 »
As are most "mechanics" but that's they way of things in garages.....only cranked for about 10secs or so before it started  ;)
Bout to get stung again....as cba.....breaking at 30-40 ish is uneven.....and breaking at 70 produces steering wheel shudder....I reckon its warped disks.....not had that on a car for a long time.....but maybe Ford disks aren't as thick as other makes  :-\
Lincs Robert
« Reply #8 on: 26 August 2017, 20:32:04 »
I had Brembos on my last Mondy, which was a 2.5T 5 cyl. I think GSF have them on offer this weekend.  :y This one was a Lex lease car in its life before me - I got hold of the full parts history - had new Motocraft discs/pads fitted just before the end of the lease.
Lincs Robert
« Reply #9 on: 11 September 2017, 19:05:17 »
I chickened out in the end, after reading horror stories on the Ford forum.  :(
I had a spot of luck though, popped into my local Ford dealer on Saturday morning with said filter - said I needed help & could I book it in for them to change. They offered to do it there & then for me whilst I waited  :y. It all worked out nicely in the end .......
« Reply #10 on: 11 September 2017, 23:02:25 »
These modern engines need priming via software, I've done a fuel filter change on the VW. 5 screws and sub 5 mins to change the filter, once new one is in I had to activate the pump via software and run it for 3 mins to bleed air out.
Started on button afterwards, picks up better low down now. Apparently fuel filters every 60k, mine had done 30k, could feel the difference.
VCDS/VAGCOM does come in very handy....
« Reply #11 on: 12 September 2017, 08:09:30 »
What a truly shit system!
« Reply #12 on: 12 September 2017, 08:15:57 »
Seen most diesels need to be primed via software? Unlike old 1.9's and non common rails were ignition off/on works.
Why is this any different to BMW diesels or Vauxhalls lumps? All still need priming.  :-\
Also a damn site nicer job than Omega fuel filter  :)
« Last Edit: 12 September 2017, 08:17:48 by tunnie »
« Reply #13 on: 12 September 2017, 10:00:58 »
Most common rails can be primed with ignition.  Its older systems that generally need priming/bleeding.  Having to need access to dealer level equipment - i.e., more than a simple service reset tool - to do basic servicing is unacceptable in this day and age.
« Reply #14 on: 12 September 2017, 10:05:19 »
Given electric hand brakes, no dip stick engines, not even an engine temp gauge on a BMW 235i....
It's a fact of life sadly now, also given Hybrids appear to be the new diesel I doubt you will be able to access the spark plugs in a few years. Without having to strip half the engine down.
Page created in 0.048 seconds with 16 queries.
