Battery reccomendations ?
Started by Migv6 le Frog Fan, 29 August 2017, 19:18:04
Migv6 le Frog Fan
My old 190 is a 5 cylinder 2.5 diesel, which runs on wvo, which means it needs to spin over pretty quickly to get it started.
The battery is a newish Halfords 096, 70ah, 640cca and struggles a bit so I'm thinking of pitting something more pokey.
Any recommendations of what to buy and where from ?
Tia.  :)
Viral_Jim
I use Tayna, if you know the Type, they will give you a selection (usually 10 plus options) at various price points. They also show all the vital stats of each battery so you can choose between them. I ordered a battery for the Swede on Friday and it arrived today, you also get a 1hr delivery slot.  :y
They are showing the 190 as a type 96. If that's true then these are your options.
https://www.tayna.co.uk/096-Car-Batteries-G30.html
PS. Viewing on a mobile device cuts out on the vital stats, so view on a of.
Lincs Robert
Quote from: jimmy944 on 29 August 2017, 19:28:26
:y + 1
Migv6 le Frog Fan
#3
Many thanks. Tayna is the seller I have been trying to remember all day. ;D :y
As for viewing on a mobile device - Ive had a phone capable of that for years, and I have yet to attempt it.  :-[ ;D
Think I might go for this one.
https://www.tayna.co.uk/E44-Varta-Silver-Dynamic-Car-Battery-P7726.html
zirk
I bought a couple of Exide for a Transit Diesel from carpartsbargains off the Bay, worked out about £46 each plus free Delivery a few months back, cant remember if they were 100 or 096 types though. Theve been fine ever since.
Migv6 le Frog Fan
Will take a look at them too. Thanks Queeny.  :-*
Migv6 le Frog Fan
Looks good for the money, but the CCA is probably a bit low for my situation.  :y
I put a Yuasa professional battery in my Omega last time (all my motor factors had when I needed it) and it spins the engine over noticeably quicker than the GM one ever did.
zirk
#9
Quote from: Kevin Wood on 29 August 2017, 21:48:29
TBH Ive never rated GM Batteries, I have loads of shagged ones Ive taken out over the years.
In fairness, the GM one was, AFAIK, the original, so 4 years old when I got the car, and it lasted another 4 or 5 years, so can't really grumble.
TD
Quote from: Kevin Wood on 30 August 2017, 09:43:28
That is good....I reckon car batteries are good to 4-5 years...on a car that's used just about everyday...
Quote from: Migv6 on 29 August 2017, 21:33:13
Fair does, it spins over my 6 cylinder 3 litre diesel lump nicely, but yes you might need a bit more power for the winter when your fuel is a bit thicker!  :y
