Author Topic: great mpg  (Read 1342 times)
JWDF
great mpg
« on: 07 August 2008, 22:22:35 »
Hi all just came down from Uig in the Isle of Sky yesterday
got this reading 51.3mpg  :) :) hope you can see this  :y  click photo
http://[URL=http://s203.photobucket.com/albums/aa7/goninodathat/?action=view&current=bf47b3b5.pbw][IMG]http://s203.photobucket.com/albums/aa7/goninodathat/th_skytuesday5th2008041.jpg[/IMG][/url]
Re: great mpg
« Reply #1 on: 07 August 2008, 22:24:41 »
Fairly easy to get that out of a tractor over a short run (assumed you reset mpg same time you reset trip distance)...
robbo299
  • luton, beds
Re: great mpg
« Reply #2 on: 07 August 2008, 22:26:07 »
As you say you came "down" from Uig i take it that it was downhill all the way and you coasted most of the time. ;D ;D ;D
JWDF
Re: great mpg
« Reply #3 on: 07 August 2008, 22:34:11 »
yes reset several times seen 56.00 once am really impressed did a lot of overtaking too.
was in Devon last week with eeerrrgh  ;D somthing tied behind got 30-34--
 ::)---think i got away with that ;D  ;D
robbo299
  • luton, beds
Re: great mpg
« Reply #4 on: 07 August 2008, 22:37:57 »
Ah Ha.... so it was you i was stuck behind on the M5 for 3 hours was it! :o :o :o ;)
JWDF
Re: great mpg
« Reply #5 on: 07 August 2008, 22:44:40 »
 :)came up from Tiverton on Fri 8th got stuck in 3 jams ::)
coasting downhill i get 999.99 mpg ;D ;D
Re: great mpg
« Reply #6 on: 07 August 2008, 23:01:26 »
On a motorway run tonight, I got 21.6mpg :y
Re: great mpg
« Reply #7 on: 08 August 2008, 01:22:47 »
My average is showing that.
Re: great mpg
« Reply #8 on: 08 August 2008, 09:36:11 »
That wouldn't have been too bad on LPG.  ;)
Re: great mpg
« Reply #9 on: 08 August 2008, 09:42:20 »
Unless you were in to 3 figure speeds, thats not good.
Re: great mpg
« Reply #10 on: 08 August 2008, 09:55:15 »
I hit 90mph on a couple of occasions but for the most I was hovering on the 80 mark.
Did another run this morning, 35 miles at 80, and 35 at 90 - got 22mpg..
Re: great mpg
« Reply #11 on: 08 August 2008, 09:56:28 »
Still sounds a little on the low side
« Last Edit: 08 August 2008, 09:56:46 by jimbob »
Re: great mpg
« Reply #12 on: 08 August 2008, 10:02:49 »
On a constant 80-90mph (continental) run, I get low/mid 30s out of the MV6
Re: great mpg
« Reply #13 on: 08 August 2008, 10:27:18 »
As said, I think it's partly due to the autobox, partly due to the fact I dont think the engine is setup properly (valve timing + needs service) and also 'cos I've got a whacking great gearbox in the boot, which is going to be fitted tomorrow :)
Dont forget I am also having engine management issues which I will investigate once the gearbox is fixed - I am getting low voltage codes for one lambda, and the dreaded code 19...
Re: great mpg
« Reply #14 on: 08 August 2008, 10:29:29 »
ahhh yes, all vital points
