I need a source of new headlights for Omega B 03 plate
Started by Mike1962, 11 September 2017, 17:36:49
zirk
Quote from: redelitev6 on 12 September 2017, 18:15:33
Sounds daft but it's worth trying old fashioned "brasso" to polish up the lights as well as solvo autosol chrome polish .
Probably but they,do need roughing up first, so probably easier with wet and dry.
Any sort of reasonably abrasive polish will restore the finish, but you need to remove the worst of the grot with wet&dry paper first. The key to any sort of polishing is to start with an abrasive just coarse enough to start the process, beginning with a fine grit doesn't give satisfactory results.
I don't consider a clear coat necessary; if you do a good enough job of refinishing the lens it will last for years.
Quote from: Nick W on 12 September 2017, 21:25:56
That's my experience :y
I probably spent too much time on mine TBH, but it was worth it.
Gaffers
Quote from: TheBoy on 12 September 2017, 13:29:48
Quote from: migmog on 12 September 2017, 13:02:58
Quote from: VXL V6 on 12 September 2017, 11:18:44
The problem I have found is that once you have used the 3M / sandpaper kits is that the headlight will yellow again extremely quickly as there is no UV protection at all.
Apparently clear coating them, applying some UV barrier polish or some form of protective film are supposed short term answers.
this stuff might work http://www.ebay.co.uk/itm/382100459169
Have you tried it?
Unless UV stable, traditional epoxy will degrade quite quickly and will likely be worse than it was originally.  Plus you would have to have a physical key to the plastic lens for it to adhere properly which means there is no way of getting a decent result.
Quote from: Guffer on 14 September 2017, 11:13:49
Have you tried it?
And it needs to be applied perfectly, as any unevenness could cause glare to oncoming traffic.
Gaffers
Has anyone tried the Autoglym headlight restoration kit?  I fancy giving it a go on the jaaag headlights but if it a waste of twenty notes then I will just do the wet'n'dry + brasso trick.
raywilb
Quote from: Mike1962 on 11 September 2017, 17:36:49
My 03 saloon has just failed it's annual medical on the headlights not letting enough light out! They are rough and the coating has come off.
I need both sides.
It's an 03 Saloon CD
Cheers
Mike
I did mine last week  auto-glym  plastic headlamp restoration kit. restored mine to a bright shiny finish. Halfords price £24.99. (I got a discount using an abs card .paid £21.24p ) I needed to borrow a decent drill as mine is not holding enough battery life.  :y
Mike1962
Hi,
Thanks for all the advice.
I got new lights for the B series here:
https://www.buycarparts.co.uk/opel/omega-b-25-26-27/13647/10533/headlight-insert
The site says .co.uk
But they're coming from Germany.
Let's see if they point the right way!
Mike
Quote from: raywilb on 18 September 2017, 12:38:03
I need both sides.
Cheers
Mike
Just under £19 on Halfords Trade :y.  Looks pretty similar, but not quite same, as the 3M kit :)
omega2018
Quote from: Mike1962 on 20 September 2017, 17:01:10
Hi,
Mike
have they arrived yet?  are yours HID lights?
