I need a source of new headlights for Omega B 03 plate
Started by Mike1962, 11 September 2017, 17:36:49
Mike1962
My 03 saloon has just failed it's annual medical on the headlights not letting enough light out! They are rough and the coating has come off.
I need both sides.
It's an 03 Saloon CD
Cheers
Mike
zirk
Mike1962
Quote from: b4ndit on 11 September 2017, 17:39:18
http://www.replacementheadlight.co.uk try these :y
Many thanks,
They say Omega b up to 2000 and Omega C 00-03
Is that right?
They only have for what they say is up to 2000
Mine's an 03
Will they fit?
M
Migv6 le Frog Fan
Mr Gav
I have both headlights left over from my MV6, both with aluminium adjusters and the lenses have been cleaned up with a 3M kit.
Quote from: Mike1962 on 11 September 2017, 17:55:21
Many thanks,
Is that right?
Mine's an 03
Will they fit?
M
Which is a perfectly good reason to avoid the company. As there never was, and will likely never be an Omega-C
The problem I have found is that once you have used the 3M / sandpaper kits is that the headlight will yellow again extremely quickly as there is no UV protection at all.
Apparently clear coating them, applying some UV barrier polish or some form of protective film are supposed short term answers.
zirk
Quote from: VXL V6 on 12 September 2017, 11:18:44
Tried some of that UV Protection coat myself after doing mine, it was rubish didn't last 5 mins before peeling off, cut the lights back again and applied a few coats of Alloy Wheel Clear Laquer on them then lightly cut it back again, been fine ever since.  :y
omega2018
this stuff might work http://www.ebay.co.uk/itm/382100459169
Quote from: migmog on 12 September 2017, 13:02:58
Have you tried it?
zirk
You need to be a,bit careful what you coat on them bearing in mind  the lens are plastic.
omega2018
Quote from: TheBoy on 12 September 2017, 13:29:48
Have you tried it?
I have used this stuff a lot but never on a headlight so as they say test on an inconspicuous area first.  can't see why it wouldn't work, it is solvent free  and is epoxy so sets solid, adheres well and will be reasonably heat resistant.  it sets clear and is uv resistant suitable for exterior use.  I have used it on toughened glass outdoors and it has held up for 2 years so far.  normally it is used to coat surfboards etc..  they do a faster setting one which may be better to avoid dust getting entrapped.
redelitev6
Sounds daft but it's worth trying old fashioned "brasso" to polish up the lights as well as solvo autosol chrome polish .
