Laminate Flooring
Started by Sir Tigger KC, 08 October 2017, 12:00:03
Is there any major benefit in having a thicker plank, ie 12mm over 7mm?
I've always used a 7mm plank which has been fine, but I've had a good quote for a 12mm plank which will work out about £100 more and I'm unsure if it's worth the extra.  :-\
It's for a lounge in an old terraced house and the floor is slightly uneven in the middle where the lounge was knocked through.  I'm wondering if the thinner board will ride over the uneven bit better.  :-\
TIA!  :y
Quote from: Sir Tigger QC on 08 October 2017, 12:00:03
TIA!  :y
You have answered your own question. :)
Quote from: Field Marshal Dr. Opti on 08 October 2017, 12:01:56
Thanks for your input M'lud, but I always like to see what the opinions of our more intelligent members are.  ::)
Someone will be along shortly.  :)
Quote from: Sir Tigger QC on 08 October 2017, 12:05:30
You could spent the £100 on a couple of gallons of finest 'Darzett Scrumpy'. :)
Quote from: Field Marshal Dr. Opti on 08 October 2017, 12:09:55
This is true and as I will never sit on this particular floor drinking my scrumpy part of me thinks I might as well save the cash.  :y
The other part is wondering if I've missed something in the dark complexities of laminate flooring.  :-\  ::)
Hard to believe I know, but I am one of the more intelligent members here at OOF. :)
This is a forum for clapped-out owners talking about clapped-out Omega. Best not expect too much in the way of erudite conversation. :) ::) ::) ::) ::)
Quote from: Sir Tigger QC on 08 October 2017, 12:15:11
[/highlight]
The girls won't get carpet burns on their shoulders and arse with laminate. :)
Quote from: Field Marshal Dr. Opti on 08 October 2017, 12:20:45
[/highlight]
A bit hard on the knees maybe?  :-\  ;D
Go for the 7mm, 12mm (nearly 1/2"  :o) is a complete waste of time in that application. Try and even the floor out as much as possible and use a decent, thickish underlay.
Quote from: STEMO on 08 October 2017, 12:45:46
That is what I told him. :)
Quote from: Field Marshal Dr. Opti on 08 October 2017, 13:07:11
Yes........more or less  ;D
I use the 5mm foam type underlay which is really good for evening out uneven bits.  :y
Rods2
I wouldn't expect M'lud to know anything about cheap laminate flooring where he insists on nothing but the best solid hardwoods to walk on and ahem other things. ::) ::) ::)
Quote from: Rods2 on 08 October 2017, 22:07:21
I wouldn't expect M'lud to know anything about cheap laminate flooring where he insists on nothing but the best shagpile Axminster to walk on and ahem other things. ::) ::) ::)
Amended!  :)
Rods2
Quote from: Sir Tigger QC on 09 October 2017, 01:16:47
Amended!  :)
;D
But the hardwood flooring explains the high-speed high acceleration falls to his laptops and required repairs after he's caught with the chambermaid on the shag pile rug, stoking the fireplace. ::) ::) ::)
