WiFi extender
Started by Shackeng, 16 October 2017, 16:10:41
Shackeng
Amazon have a WAVlink N300 for £17. Has anyone used these or have any knowledge of them? I need to use wifi to reach the Mondeo on the drive, and also for the iPad in the garage. :-\
TD
They do work....but don't expect any great speed through them...probably about 11Mb/s at best  ;)
So no good for streaming....but ok for emails web browsing etc  :y
Shackeng
Quote from: TD on 16 October 2017, 16:48:55
Thanks Dave, no streaming, just need to update the Mondeo software, and get OOF in the garage.
Cheers. :y
Wifi extenders are all universally shite.  Not just slightly shite, but universally shite.
Not only are they shite, but if your wifi device is a bit shite, it will make it so much worse.  And no solution, due to the way they *have* to have the same SSID as your router.
If you need something, the less shite power line adapters are a better bet - one with wifi and ethernet (in case your device has ethernet).  This is certainly what I use in my garage, where the garage PC is.  Mine is one of the £50 BT ones (not inc staff discount), and gives in the garage 2 ethernets and 1 wifi.  I keep the wifi on a separate SSID to home router to stop my dumber devices connecting to that rather than the router wifi.
Lincs Robert
Amazon sell a nice little range from Coredy, I use them as additional WAPs, so they are hard-wired back to the main router.
The one I've been using since garage was rebuilt is the slightly older version of this
https://www.shop.bt.com/products/bt-wi-fi-home-hotspot-plus-600-kit-084286-BVFB.html?q=bt%20extender
Which is showing me £45 (I might still be logged in though, so if its showing you more, let me know)
Shackeng
#6
Quote from: TheBoy on 16 October 2017, 18:10:12
I've already got two power line adapters supplying TV's in different rooms, but can't see how they would help with getting wifi to the car, and reluctant to pay 70 quid for the one in the link. Does that one give out wifi from the second plug? :-\
Quote from: Shackeng on 16 October 2017, 18:43:49
Yes.
If you already have compatible powerline adapters at home, just buy the remote end. Don't think BT sell separately, but others do - ideally go for same brand as your powerline stuff, but not essential if all bits follow the spec.
Quote from: TheBoy on 16 October 2017, 18:36:51
£69.99.
Quote from: STEMO on 16 October 2017, 19:06:01
£69.99.
OK, so clearly my stupid gay crapBook isn't deleting the cookie.  I would suggest that that exact make could be bought cheaper from other outlets ;)
Shackeng
Quote from: TheBoy on 16 October 2017, 18:56:58
Yes.
Ta, I'll look into that. :y
Shackeng
Got a wifi extender same make as my homeplugs, wifi now fine in the garage, connected in the Mondeo but, wifi goes into continuous search, and seems unable to find the 2017 Sync3 2.2 update. :(
Shackeng
Been using the Aztec (Solwise) Powerline HL117EW extender paired with the Powerline HL117EP adapters since this post, and which has worked OK until recently. 115's are still working but the 117 stopped, and now will not pair. Naturally these are discontinued >:(, so I now need a decent WiFi extender, that does not need a mortgage.
Any recommendations please?
Shackeng
Or do the 3 year old recs above
stand?
There is no such thing as a good wifi extender.  Its generally the worse of all solutions.
Solutions in order of reliability (and speed):
Cable
Powerline
Extender
Currently for power line, I would recommend TP-Link stuff, as they generally seem to last, and usually give a pretty stable link in most modest houses.  But obviously a cable is always much, much, much better.
