'02 2.2 16v Estate shopping list...
Started by Doctor Gollum, 18 October 2017, 14:28:41
As above... there's a few bits that I am after.
1. Cable tray cover (with or without the cable tray) that runs across the front of the engine.
2. Roll up or metal dog guard preferred (once common on plod estates) but only the genuine ones.
3. Charcoal Load cover, with end caps, must be facelift.
4. Scuttle drain grommet, pollen filter side.
5. Set of carpet mats.
6. Working front central locking motor.
7. Pair of charcoal screw covers from front door card.
8. Cruise control stalk and clutch switch (with length of loom).
9. Pair of working two button remote fobs, button condition not important.
The load cover, load net and mats aren't urgent, and will obviously need collecting/oof couriering unless all from same person, in which case postage becomes viable.
Much obliged. :y
Quote from: Doctor Gollum on 18 October 2017, 14:28:41
10. Pair of illuminated sunvisors.
11. Pair of rear reading lights plus B pillar looms and door switches.
Much obliged. :y
Forgot a couple of things ::)
Shackeng
Got some door motors Al, not sure which is front. :y
Quote from: Shackeng on 18 October 2017, 15:29:35
Fronts are 90493702/605328
omegod
So far I have:
2 x working 2 button remotes
1 x scuttle grommet
Front locking motor
1 x grey screw cover, will have more somewhere
2 x illuminated sun visors
Chuck me an offer for these if you wish
I really should have the rest but there's quite a stash to go through
biggriffin
Hoof'land storeman.
Quote from: omegod on 18 October 2017, 17:42:02
So far I have:
1 x scuttle grommet
Front locking motor
Pm sent  :y
Quote from: Doctor Gollum on 18 October 2017, 15:21:15
Much obliged. :y
A few bits sorted thanks to Omegod :y
Shackeng
Quote from: Doctor Gollum on 18 October 2017, 15:44:53
I've got a couple of those Al, one was u/s when removed. You can have the other, plus a m/s in case in needs the KW repair. PM your address. :y
I can do 2, 3, 10 and 11 from the car that Bambi did :D
Quote from: Lazydocker on 22 October 2017, 08:27:51
I think I may have a metal dog guard but now I'm not 100% certain I've got a spare. I'll confirm.
Quote from: Doctor Gollum on 18 October 2017, 22:42:58
Much obliged. :y
Quote from: Doctor Gollum on 24 October 2017, 19:08:18
7. One charcoal screw covers from front door card.
Much obliged. :y
