This compressor worth buying ?
Started by Migv6 le Frog Fan, 20 November 2017, 19:08:20
Looks exactly the same generic chinese model I bought from Machine Mart, must be 8 or 9 years ago now, and for about the same price back then, so certainly good value. Won't power serious air tools without stopping for breath every so often but fine for amateur use. :y
powerslinky
#2
Albs, I have the same thoughts as Kevin   . . . looks the identical to mine except colour & brand transfer. it  was  circa. £95 .00 delivered.
Had it 3 or 4 years now , very useful bit of kit .  Look to buy a better air line & also it did not come with a post compression   filter/water trap  . . but easily fitted for a tenner.
Blows up tyres just as good as dynamite  LOL !  ;D ;D
With all the bits and bobs that looks like a great price!  :y
Webby the Bear
SGS also do some dirt cheap (relatively speaking) tool boxes  :y
RIP Paul Lovejoy
redelitev6
Same as mine , good for light usage but it will struggle if using air hungry tools , my air saw had it running nearly continuously , just be careful of the fragile air hose connector/regulator connection , they can ( and do  :-[ ) snap off easily .
.. and bin the tap that's supposed to fit to the output, as they're very restrictive.
They aren't rated for anything like continuous running, so do need a rest from time to time if the tools are giving them a caning. I normally remember to let it sit for a while when I start to smell the varnish from the motor windings. ::)
Olympia5776
You can't go wrong with that at that price inc. accessories Albs.
I have one very similar that I bought about 6 years ago .This was to prevent me having to load the large workshop one I also have into the van.
It has been a godsend in those years being used many many times , even more often than the other one . I used it yesterday as the job was small ( spraying bumpers ) and it was just so easy and quick to set up.
I use it for all types of paint , schutz , timber treatment even plumbing work.
Keep the filter clear,change the compressor oil every year and exhaust the air and drain the water from the tank after each use to protect the seals .
Get one of these too .
https://www.ebay.co.uk/itm/UK-1-4-BSP-Air-Compressor-Moisture-Trap-Oil-Water-Filter-Regulator-Lubricator/332285974147?hash=item4d5dc99683:g:UsgAAOSw0j9ZWg4G
Don
I have one of these (not this brand but looks so near as identical that I assume they all pop out of Chairman Mao's industrial womb): https://www.sgs-engineering.com/air-compressors/semi-pro-diy/sc100v-100-litre-high-flow-air-compressor
Definitely head and shoulders above the one I had before (single cylinder, per your link). That said, you can't hear yourself think over either of them, let alone speak ;D
A friend has one of these: http://www.ebay.co.uk/itm/241187-Workshop-Garage-90-Liter-Silent-Oilless-Air-Compressor-4-Motors-2200W/272471814911
It's bloody brilliant - damn near silent, the motors start sequentially so the lights don't practically go out when it kicks in.. the only down-side was that it was delivered by a single guy in a van, so you need to be feeling strong the day it turns up! ;D
Yes, I've got a little single motor rocker compressor like that for pumping up the radio club's mast. Very, very quiet but doesn't shift a great deal of air, hence all the motors on that one, I guess.  ;D
redelitev6
Quote from: aaronjb on 21 November 2017, 09:30:07
[/highlight] Whoa ! now were talking compressors
When people say hungry air tools, cope with wheel nuts? Shock bolts? Could this crack wheel nuts?
I know things like shock bolts would need manually breaking first.
1/2 impact wrenches, drills, die grinders, sanders, full-size sprayguns, ratchets, hammers are all hungry air tools. Unless you get a reasonably sized compressor(100l tank and 3HP) you're going to be very disappointed. And they're really inconvenient, inefficient and noisy for DIY use. I've had mine for 25 years, and tried most of those tools with it: it only gets used for painting. I bought electric grinders, sanders and polishers because they're actually usable.
Keith ABS
  What Nick says. Better to have a larger tank
Keith ABS
It depends what you intend to use it for.
For tools that get use for long periods of time such as grinders, drills, etc. then yes, this compressor is not suitable. It will spin wheel nuts off with an impact wrench, inflate tyres, run a small sand blaster / paraffin gun to clean parts, blow dust out of your PC, pressurise your cooling system to look for leaks, work a spray gun, at least well enough to paint single panels at a time and many other things.
I wouldn't be without mine, that's for sure, but I wouldn't be able to justify the space or expense consumed by a more powerful compressor either.
