Wanted Urgently: Windscreen Fluid Pump
Started by tunnie, 20 November 2017, 20:43:03
Due to the output pipe snapped off, could do with a working screen wash pump. (windscreen pump)
3.2 Facelift
I could also do with some screen wash tubing.
zirk
To get you out of trouble, can you not pull out the Headlight wash one and use that, fairly sure Ive done that in the past, or did I dream it.
As for the pipe any good Motor Factors.
Good suggestion, but pump looked very different, least at 8pm a night.  :-\
Is the pipework 3 or 4mm?  :-\
Keith ABS
Maybe, will check if and what I have, if I can find it
Keith ABS
annihilator
Headlamp tubing is larger bore.I've got pumps if you want one £10 inc p&p.
Sorry just sourced a new one off the bay.
Quote from: annihilator on 23 November 2017, 13:37:06
no problem  :y
Which turned up with wrong connector  >:(
Just done a 'fix' to old pump, will test this tonight. May still need it  :y
Quote from: annihilator on 23 November 2017, 14:53:06
Okey dokey. :)
Just dropped you a PM, fix not ideal. So would like this pump if still available  :y
