Author Topic: I am a MUPPET!! (Dropped something in a bore)  (Read 7323 times)
STMO123
Re: I am a MUPPET!! (Dropped something in a bore)
« Reply #30 on: 10 August 2008, 20:55:37 »
You may not have to burn it up. Leave the spark plug out and fire it up. I think it might just 'pop' out. :-/
That was going to be my suggestion...except disconnect something to stop it firing, just turn it over on the starter for a few seconds..
You really need it to fire so that it gives the full OOMPH!!
Yep. Just not for too long long, DIS pack's are a bit fussy about misfires.
markey mark
  • SLady bitshorpe north lincs
« Reply #31 on: 10 August 2008, 20:56:25 »
it will burn up in seconds james dont worry about it  :y
« Reply #32 on: 10 August 2008, 20:57:00 »
That's my opinion... Just giving other options too :y :y :y
STMO123
« Reply #33 on: 10 August 2008, 20:59:48 »
I think it might poison the cat.
markey mark
« Reply #34 on: 10 August 2008, 21:01:00 »
doubt it very much only a bit of silcone rubber which is a hydrocarbon and will fry instantly and turn to oil vapour  :y
philhoward
  • Staffs
  • Love the engines, so put one in something else..
« Reply #35 on: 10 August 2008, 21:02:03 »
Doesn't silicone kill Lambdas, though????
Running an X30XE in a Reliant Scimitar GTE as I can't have an Omega as a company car...
markey mark
« Reply #36 on: 10 August 2008, 21:03:03 »
in massive amounts yes but not a small piece of rubber  :y
« Reply #37 on: 10 August 2008, 21:03:07 »
It is the size of a baked bean or two, so it's really not a lot. I would worry about it gumming up, but certainly not knackering the cat.
Is it likely to damage a piston ring?  :-/
STMO123
« Reply #38 on: 10 August 2008, 21:03:51 »
I dont even know why we're debating this. James will pull the head off it, he just cant help himself.
I've told him he'll go blind
markey mark
« Reply #39 on: 10 August 2008, 21:03:52 »
no more likley to damage a valve james
Big_Roger
  • Southampton
« Reply #40 on: 10 August 2008, 21:07:40 »
Hi,
Try vacuuming it out.  If you can get a short length of 8 or 10 mm tube, even bit of thin wall electrical cable sleeving biggest you can get to go down spark plug hole, fix into the end of vacuum cleaner hose, and get seal with electrical or duck tape. "Wiggle" this around inside the cylinder.
I would have thought you would get enough of a vacuum for the piece of rubber, depending on size, to at least either get sucked out or at least get stuck over the end of the piece of tube so you could gently pull it out.
Failing that, I would go with the suggestion to leave plug out an start up when you can. I reckon it will take path  of least resistance and get blown out of the plug hole. If you don't put something over to catch it, I don't reckon you'll even see it go.
HTH
Roger
Be patient ! Something else will go wrong for you to fix if you wait long enough !!
Bandit127
« Reply #41 on: 10 August 2008, 21:09:32 »
Is it really silicone rubber? Like bath sealant?
If not, it will burn up in to carbon and hydrogen.
If it is silicone rubber, it's melting point is much higher. Take the plug out, earth it on the block and give it 1,500 revs. It will blow out.
Your earthing needs to be good or you're in for a shock....
« Reply #42 on: 10 August 2008, 21:22:24 »
it's whatever plug leads are made of...
Taxi_Driver
« Reply #43 on: 10 August 2008, 21:27:32 »
You are probaly right  ;D ;D
JueV6
  • Kent
« Reply #44 on: 10 August 2008, 21:30:08 »
1st post on this thread was 18:46, it's now 21:30...
James you could have have the head off and 1/2 way to being finished by now... :y :y :y ;D ;D ;D ;D
