Author Topic: I am a MUPPET!! (Dropped something in a bore)  (Read 7322 times)
« on: 10 August 2008, 18:46:10 »
On my 3.0, I was changing the spark plugs.
I removed the plug on no 4, and as I did so, a piece of rubber (from the end of the plug lead), has fallen into the Bore.
I can't get it out, I've tried all sorts.
Presumably I should now remove the cylinder head to get it out?   ::)
Re: I am a MUPPET!! (Dropped something in a bore)
« Reply #1 on: 10 August 2008, 18:50:13 »
air gun on an airline?  :) get it right in to the bore so it blows out of the well not in.
« Last Edit: 10 August 2008, 18:52:15 by chrisgixer »
« Reply #2 on: 10 August 2008, 18:50:54 »
Can you bowwow a compressor and try and blow it out.
If it's rubber cant you flush it out with a water jet.  Not the best way to do things, and maybe not the most practiacl, but maybe far quicker than taking the head off. :y
« Reply #3 on: 10 August 2008, 18:51:39 »
I can't get an airline anywhere nearby - I am at Maria's...
« Reply #4 on: 10 August 2008, 18:52:54 »
Piece of windscreen washer pipe and a sharp blow down it?
« Reply #5 on: 10 August 2008, 18:53:50 »
bit of pipe and blow like fock?
« Reply #6 on: 10 August 2008, 18:54:44 »
I am wondering, maybe fill the bore with water and let it float up to the top....
« Reply #7 on: 10 August 2008, 18:54:58 »
bah ... he keeps beeting me to it. ;D
JueV6
  • Kent
« Reply #8 on: 10 August 2008, 18:55:47 »
James pm sent
« Reply #9 on: 10 August 2008, 18:55:54 »
Type faster.  PMSL
v6coop
  • Nottingham
« Reply #10 on: 10 August 2008, 18:56:42 »
How big a piece was it? If it was metal I might worry, but a piece off the spark plug boot will burn up in no time. If you can't get it out personally I would not be too phased. Certainly not to the extent of taking the head off. Mind you there is an excellent how to written by someone called JamesV6CDX :D ;D ;)
JueV6
  • Kent
« Reply #11 on: 10 August 2008, 18:59:34 »
UNCALLED FOR ;D ;D ;D ;D ;D ;D ;D ;D ;D
But i agree if it's just the rubber is may even drop past the open valve just by turning it over
« Last Edit: 10 August 2008, 19:01:31 by Juedu2 »
« Reply #12 on: 10 August 2008, 19:01:46 »
Lol, I'm not phased by taking the heads off... just unsure if Maria's nosey neighbour will call the Police   ;D
Dave-C
  • Staffordshire
  • The Old Girl
« Reply #13 on: 10 August 2008, 19:06:54 »
Take his head off instead ;D ;D ;D ;D
If it's rubber I'd agree with the above, is may well burn off pretty quickly.... ;)
DC
« Reply #14 on: 10 August 2008, 19:07:32 »
might sit by the cats and stink, cant see it doing to much damage tho??? :-/
