Medium term garage roof fix
Started by grifter, 09 January 2018, 21:37:37
grifter
Hi All
Looking for some advice if any builders or roofers on here. I've got a garage (check me!) that has the standard tar felt flat roofing. trouble is it is really overdue for total renewal, and is leaking, but at the moment can't quite stretch to funds to totally repair. Was going to do it myself but going to be busy this year so have heard there is a type of covering/sheeting you can buy that you can put over the roof, I think it is the same thing they use for lorry curtains.
Does anyone know a good source for this or something similar I can put over roof for waterproofing until I get funds to buy material for new roof?
I also would like to add a layer or two of brick to the walls to raise the roof a bit as it is very low, or at least to put more of a run on it for drainage, so I would be a bit hesitant to just take all the old roofing off and not put some extra bricks on while it's all off.
Rods2
If you want a cheap repair then do what I have done by adding a layer of shed roofing felt to my front flat roof that actually lasted longer than intended or expected for over 5 years before it started leaking again. I've got to do a complete repair this year with new boards and will use a one piece rubber sheet which is then meant to last 40-50 years. 10m x 1m shed roofing costs £30 at my local hardware store along with £25 for 5L of felt adhesive along with a few £££ss for a couple of boxes of clout nails. I did the same shed roofing felt repair on my newer rear & garage flat roofs last year where the roofing felt had just cracked on the gutter side edge and it is still all fine and leak proof 18 months later.
I've found the paint on repairs don't last very long!
flyer 0712
I had the same problem with the garage last year.. leaked very badly  like a sieve in several places.. I used Thompsons 10 year Roof seal  which I bought at Wickes for about £18 for a two and a half litre tin.. 12 months later all is still good, you can paint it on even in the damp conditions as long as you let it dry before recoating it if it needs it... so well pleased with the results and way cheaper and easier than recovering  the 30 foot by 11 foot roof. :y
Viral_Jim
Quote from: Rods2 on 09 January 2018, 21:59:05
https://www.toolstation.com/shop/p24314?table=no
This has lasted 4yrs and counting on our shed roof. Although as always it depends on the type of leak you are trying to repair. We used it as the wooden shed abutted two walls and the roof wouldn't support my weight. So re-felting (my preferred option) was impractical.
EDIT: wot flyer sed ;)
flyer 0712
That's the stuff ...Jimmy...brilliant as far as I am concerned  :y
grifter
Is that the firestone stuff? My folks got that on their roof, seems a good long-term fix as the felt and corrugated stuff it had before lasted barely 10 years before leaking.
Bigron
Before reading Jimmy's post, I was going to suggest RoofTrade, a similar product that also comes in aerosol form. I got mine at B&Q; sorry I cannot remember the price, but I have a fwwling that it was cheaper.
Anyway, no need to replace that roof until you are ready to, Grifter!  :y
Ron.
Rods2
Quote from: jimmy944 on 09 January 2018, 22:30:28
I think it is going to depend upon the type of roofing problem. My front roof has chipboard boards and is fairly unstable which the roofing felt could cope with and the newer roofs it was not an option as the tar used for gluing the folded over edging top cap on the guttering side meant over 15 years it had heated in the sun, lifted and split, so roofing felt was the only practical option for a temporary repair.
jonathanh
I'd suggest laying a single sheet rubber roof.  I used rubber4roof.co.uk on a porch.  Its not difficult to lay yourself.
If you are raising the roof then i expect you'll replace all timbers so in effect you'll be laying on a new timber deck, so a rubber sheet is fine. Its no good to patch an existing hot felt roof
Others may suggest grp/fiberglass but it feels a bit of overkill for a garage and is more expensive and less diy able
Quote from: jonathanh on 10 January 2018, 06:03:54
Yes, excellent stuff and quick/easy to lay, takes longer tor remove the old stuff
redelitev6
We seem to have a lot of experts on rubber sheets  ::)
ronnyd
Quote from: redelitev6 on 10 January 2018, 12:40:53
Yeah, because most of ,em are incontinent. ;D
