Author Topic: Headlight aim  (Read 5418 times)
pauls
  • By the sea minehead
    • Bmw x3
Headlight aim
« on: 01 February 2018, 14:09:40 »
Can you adjust the beam left or right as my passenger one seems to be aiming to far over to the right.
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
Re: Headlight aim
« Reply #1 on: 01 February 2018, 14:44:52 »
Yes you can as long as adjusters aren't broken(which may be why its out ) :y
other rides
Re: Headlight aim
« Reply #2 on: 01 February 2018, 15:28:50 »
It's usually the up/down adjuster that fails though  :y
Re: Headlight aim
« Reply #3 on: 01 February 2018, 15:30:12 »
There are two Allen key hex drive screws on top, one left/right t'other up/down. It takes a lot of turns to make a difference.  :y
Re: Headlight aim
« Reply #4 on: 01 February 2018, 16:04:38 »
Audi remember, not Omega  :)
  • Chatham, Kent
    • Ghastly 1.0l Focus
Re: Headlight aim
« Reply #5 on: 01 February 2018, 17:27:54 »
I bet they use the same shitty plastic for the adjusters......
Re: Headlight aim
« Reply #6 on: 01 February 2018, 19:30:12 »
Ah! You'd have thought that Paul would've mentioned that in the OP  ::)
Paddy Flannery
  • Hertford, Hertfordshire
    • 2003 2.6 V6
Re: Headlight aim
« Reply #7 on: 01 February 2018, 20:02:07 »
There are hundreds of cars/vans/lorries on the road just now with poorly aimed headlights.  >:(
At least you've recognised it and are doing something about it  :y
pauls
    • Bmw x3
Re: Headlight aim
« Reply #8 on: 01 February 2018, 20:31:17 »
Sorry didnt think of that.. Iam asking because i keep neing flashed by oncoming cars.
Re: Headlight aim
« Reply #9 on: 01 February 2018, 20:38:18 »
 ;) Drive up to a wall / garage door & see where the beams land andgoo from there.
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
Re: Headlight aim
« Reply #10 on: 01 February 2018, 20:54:49 »
A lot of the time bad alignment, is cheapO crap Chinese bulbs, or fitted wrong.
Hoof'land storeman.
pauls
    • Bmw x3
Re: Headlight aim
« Reply #11 on: 01 February 2018, 21:35:21 »
You cant really tell off the wall. Height is fine, manual up and work. I have had time know to do a bit more research. Its looks like it has a ajuster screw. So will take a look tomorrow.
Keith ABS
  • Maldon Essex
Re: Headlight aim
« Reply #12 on: 02 February 2018, 06:33:26 »
 A lot of the time it is mis fitted replacement lamp that causes the dazzle/aim alignment problem.
Here in Essex, its about 50% of the vehicles on the road, with buses the worst offenders
Keith ABS
Re: Headlight aim
« Reply #13 on: 02 February 2018, 08:50:12 »
Oh yes you can
Drive up to the wall and place a mark where the cut off is (there is a point where the left half of the beam angles upwards)
Reverse back a few meters and adjust the aim so it is fractionally below the mark.
This is basically what a beam splitter at the MOT station does, just in a smaller more convenient package
