Uxb in the Thames
Started by biggriffin, 12 February 2018, 14:39:42
biggriffin
So they find an uxb in the river near king George dock, (500lb) it's been there 70 years, they evacuated an area of 250m, they are not moving it till tonight,  why not just drag out to middle of the Thames, or up stream a bit and blow it up,
During the blitz they just carried on.
I know them elf's might get affected.
Hoof'land storeman.
Bigron
Return it to germany and detonate?
Ron.
Lizzie Zoom
#2
There is a LOT more of those in the ground, and Thames, around London ;)
As 24,000 tonnes were dropped on London alone, and with an estimated bomb failure rate of 10%......well, a lot of devices are still there!! ;)
Lizzie Zoom
Quote from: Bigron on 12 February 2018, 14:45:02
Ron.
Well don't forget 1.4 million tonnes of bombs were dropped on Germany by the British and American air forces, so they would have an estimated 140,000 tonnes of UXB,s already :)
redelitev6
Quote from: Lizzie Zoom on 12 February 2018, 16:28:47
Ron.
And our bombs tended to be a LOT bigger than the German ones as they didn't have the heavy bombers like the allies did !
Quote from: redelitev6 on 12 February 2018, 17:23:22
.. and they weren't built by Germans, so a higher percentage of them probably functioned. ;)
Drag it onto land, anywhere within the M25, and detonate.
Kill 2 birds with 1 stone ;)
Lizzie Zoom
#7
Ron.
Yes, absolutely right :y
My favourite Luftwaffe bomber of 1940 is the Heinkel 111 and this had a maximum bomb load of 4,400 lb.  However, when Hitler decided they should bomb London and other British cities instead of bombing the RAF airfields, they had to travel further with a maximum fuel load.  That mean't their bomb loads decreased to a maximum of 2,134 lb.  This was typical of the Luftwaffe bombers used over Britain, with all having a similar, or even lighter bomb load.
Unlike the RAF Hitler (thank goodness) generally failed to successfully update his bomber fleet from what were 1930 designs, with two engines, thinking that with Blitzkrieg tactics the bombers would strike over short distances in massed fleets. Basically there was the four engined Focke-Wulf Condor flew for the Luftwaffe, but was kept for just maritime use where distances of flights (over the Atlantic) were longer. There was from 1942 the Heinkel He 177 Greif long range strategic, again twin engine, bomber that could carry a 13,228 lb bomb load, but it's numbers were small as it was basically a failure with continual engine failure and structural issues. The Germans never developed them further or increased their numbers for long distance bombing campaigns.
The RAF however developed the Lancaster and from 1942 they formed massive bombing fleets to strike Germany, and the Third Reich generally, had a maximum bomb load of 22,000 lb (equal to the post war Vulcan), but this was reduced to 14,000 when on long distance operations.  1,000 British bomber raids at night, then 1,000 American bomber raids during the day certainly guaranteed the Third Reich was hit hard, although today some revisionist historians pour scorn on this and the morals displayed by the Allies.  I say, to quote Arthur 'Bomber' Harris in 1942 when justifying the mass bombing of Germany, "They [the Germans] sowed the wind; now they reap the whirlwind".  My London East End Grandmother used to say "Too bloody true!".  I will always echo her sentiments. ;)
Bigron
Quote from: TheBoy on 12 February 2018, 17:54:57
Which 2 birds would they be, TB? You are not hinting at anti-London sentiments here, surely?
We down South subsidise you "oop-norf", so be careful what you wish for!  :P
Ron.
Quote from: Bigron on 12 February 2018, 18:23:11
Ron.
I was just thinking of improving that shithole known as Londonium.  I hadn't even begun to mention its inhabitants....
...but now you mention it ;)
Bigron
I know where the UXBs are in Brackley......
Ron.
Quote from: Bigron on 12 February 2018, 18:46:11
Ron.
I know where the XB was, but its no longer got the U bit ;)
Bigron
It is currently located in your fundamental orifice - sit carefully!  ;D
Ron.
Quote from: Bigron on 12 February 2018, 19:02:13
Ron.
That was an hour ago.  A potty visit has defused it :P
BazaJT
From what I recall Lizzie[I may very well be incorrect though]the HE177 was a four engined aircraft but the engines were "twinned" into the same nacelle and drove a single propeller per unit hence appearing to be twin engined and as you say suffering high reliability problems.Back on topic it is hardly surprising that UXBs from WW2 are still being found as even now "live"ordnance from WW1 is still surfacing on quite a regular basis in Flanders etc.
