ccr2006 radio
Started by raywilb, 25 March 2018, 22:30:04
raywilb
 I move in approx. 2 weeks & getting rid of stuff. I have a radio ccr2006 that came out of an elite that had a bose system. it comes with a code. will send it to anybody that wants one for the cost of sending it which I estimate to be about £15 to £20. first come gets it  :y
Bigron
My CCR2006 is non-Bose, but is useless as I do not have the code and cannot remove it from the car anyway. Will yours work with non-Bose?
Ron.
Quote from: Bigron on 26 March 2018, 00:47:54
Ron.
Yep :y
Bigron
Thanks James. I will make yet another attempt to remove my radio tomorrow and, if successful, will see if Ray's radio is still available. No point in asking if I cannot remove the old one.
Um, Serek couldn't remove it, so I may also fail!
Ron.
zirk
Ron.
No, it will switch On and make a noise, but wont be suited to a non Bose system as the Bose HU's are configured with a lower speaker output level (less than a Watt) which the purpose is to feed the input of the Bose Amp.
Migv6 le Frog Fan
This ^ is also my understanding.
Bigron
So it's basically a Line Output, requiring a subsequent power amplifier, yes?
Pity; but I've lived without the radio for many years, so.....
Ron.
zirk
Quote from: Bigron on 26 March 2018, 08:46:53
Ron.
No, its a Speaker Output (Unscreened Balanced) but at very low level, which as you say then feeds the Bose Amp, its just Bose's way of doing things making it totally incompatible with any other make or setup.
As said you will get something out of the speaker feed but quiet a few db's down over normal, not much help once you go over 20 mph.
BazaJT
