Cooker question
Started by Gaffers, 10 April 2018, 18:15:36
Gaffers
I have a SFO2SS which in the words of SWMBO went pop and tripped the fuse.  After which the grioll didn't work.  It's nearly 5 years old and well out of warranty so I popped the back off to have a butchers.  I quickly found the culprit by the big brown mark on the side and a quick google told me it was a temperature regulator.
I ordered a placement which arrived today.  Despite the pictures online being identical to the old one, upon inspection it appears the new part is different.  Firstly the old regulator is rated to 100C, the new one 115C.  The polarity also seems different (red mark).
Is this important or should I send it back and insist on a the correct one being sent out?
BazaJT
I'd try to get in touch with them and explain situation.The original may have been superceded by the new part you now have,or it could be that what they've sent is plain wrong!
Gaffers
Just done that but instead of someone who knows what they are talking about I got a representative  who is semi-trained in customer relations.
General gist of the conversation:
Me - I think I have been sent the wrong part
Them - does the packaging have XYZ on it?
Me - No, it has ZYX.
Them - That's ok item no ZYX = catalogue no XYZ.  It could be packaged wrong if it doesn't look the same.  You can use out online return process, blah, blah, blah....
Me - is it wrong or has it been superceded?
Them - Try fitting it and let us know.
Me- Has the polarity changed then because the red marking is on the other side?
Them - Dont know.
End of chat - How did we do?  Please give us a rating.....
:-X
Broomies Mate
Part Number:
    3570767016
Replaces:
    3570470017
    3570562011
    50027295000
BUUUUUT!
Part Number:
   3570560072
Replaces:
   3570436034
Gaffers
New part 3570560056
Old ?
Broomies Mate
Quote from: Gaffers on 10 April 2018, 19:00:13
New part 3570560056
Old ?
Old:
    3570082036
    3570436018
Broomies Mate
Do you have your 11 digit PNC code?
Gaffers
So it's ok then?  Is the polarity marked by red or is it not important?
dave the builder
It's an overheat stat ,  ;)
cuts continuity between the 2 spade terminals if too hot (115 degrees)
red dot does not denote polarity , it will disconnect when it reaches it's 115 degree threshold
Gaffers
Gaffers
Quote from: dave the builder on 10 April 2018, 19:07:47
Thats what I thought. :y
Broomies Mate
No Polarity involved.  That'll be a QC marking, or a "Yes, I'be been tested".
And yes, that is the corect part for the PNC number you gave.
Gaffers
Sweet.  Thanks a lot.  Puts my mind at ease :y
Gotta love a white goods thread!  :y
I'm still wondering what an SFO2SS is. Off to Mumsnet, I suppose... ::)
