Author Topic: PC Advice  (Read 2241 times)
HerefordElite
  • Hereford
  • Welcome to the Shire
PC Advice
« on: 13 August 2008, 23:19:06 »
I have an old K7S5A Motherboard in my PC and i can't afford to upgrade at the moment but i'm running out of HD space.
Do you think it's worth me buying a bigger HD looking at http://www.lambda-tek.com/componentshop/index.pl?prodID=1404266 which is about the best my MB will support (max ATA-100) or are newer SATA-300 etc that much better and should i wait til i retire my aging MB? :'(
Re: PC Advice
« Reply #1 on: 13 August 2008, 23:22:24 »
Go external via a USB 2 caddy, add a 500GB hard drive, then when you do upgrade you can allways add the 500GB as a slave on your upgrade. :y :y
« Last Edit: 13 August 2008, 23:28:59 by skruntie »
HerefordElite
  • Hereford
Re: PC Advice
« Reply #3 on: 13 August 2008, 23:34:25 »
Excuse my ignorance Phil but  :-?? how would i add the external as slave?
Don't really want an external :-/
but thanks anyway :y
Re: PC Advice
« Reply #4 on: 13 August 2008, 23:35:24 »
Via the USB2 socket, add it and format it as annother drive letter, or partition it and add multiple drive letters.
Just thought it might work out cheaper in the long run, most of the drives are cheap ungough, but if you buy a Sata drive, then you will need a sata/PCI card arrond £15
With a caddy, from a tenner, you can plug the drive into and PC/Laptop with a USB port.  :y
« Last Edit: 13 August 2008, 23:39:06 by skruntie »
Re: PC Advice
« Reply #5 on: 13 August 2008, 23:42:08 »
Also you can buy a bigger drive, and if I am correct just partition the ammount your board eill support, allthough unXP it will probably use the whole ammont. but maybe only when partitioned.
bappy
  • HAVANT, Hants
  • Don't fart on the leather upholstery!
Re: PC Advice
« Reply #6 on: 14 August 2008, 12:34:42 »
I beleive that running over USB there wont be an issue on drive size. you could in theory have a 100 TB disk on a usb port (i know they dont exist yet)
You need to make sure your operating system can support a large HD tho. if you're on XP make sure you install the latest service pack and you'll be fine with an external 500GB disk, vista will cope fine too. if you are on '98 or me forget it. don't know how well 2000 deals with big disks either.
as for using it as a slave, what skruntie is suggesting is that when you have finally bought a new mother board you can take your 500GB disk out of the caddy and put it in the PC as a regular internal disk.
K7S5A you say? I had one of those. Don't buy a caddy with a GS18** controller chip as they are incompatible with VIA usb controllers. If in doubt either buy a belkin USB2 card or get a firewire caddy instead of USB2.
Trust me, I'm an IT analyst :D
If at first you dont succeed, Rev it harder!
Ken T
  • Stockport
Re: PC Advice
« Reply #7 on: 14 August 2008, 13:03:55 »
another supplier of HD's at a reasonable price is CCL
http://www.cclonline.com/product-categories.asp?category_id=112
Fancy a TerraByte for £90 ?
Ken
HerefordElite
  • Hereford
Re: PC Advice
« Reply #8 on: 14 August 2008, 13:11:14 »
Running XP (latest service Pack)
was keen to stick with WD as the 40GB i got now is superb and been going strong for years (touch wood) :y
Re: PC Advice
« Reply #9 on: 14 August 2008, 19:05:30 »
I still have some of the motherboards you have as your PC upstairs, cracking board, built loads of systems based on them,
40gb these days doesnt take much filling.  But like you say an extra drive will free up some space. :y
HerefordElite
  • Hereford
Re: PC Advice
« Reply #10 on: 14 August 2008, 20:12:55 »
very old now but still a great board, learnt a bit buliding and upgrading on this one ::)
sure it's probably on The Boys gay list though i know my Athlon XP chip is ;D
Funny thing is fat old blokes on Wii's are on my gay list :D
(bye bye post count :P)
Re: PC Advice
« Reply #11 on: 14 August 2008, 20:14:57 »
Oh dear . . .  :-/
Re: PC Advice
« Reply #12 on: 14 August 2008, 20:20:25 »
Not worth spending too much on it.  Actually, I can't even give away Athlon XP machines.
Due to its age, probably lacking memory (256? 512?) and at end of its life anyway.  A low spec (but still far better than you have) base unit will be dirt cheap anyway.
I know you dont want to buy a new one at the moment, but don't spend much on yours.  If its purely disk capacity, can you burn stuff off on to DVD to free up space, or even just reformat (that frees up loads ;)) until you are in a position to upgrade?
HerefordElite
  • Hereford
Re: PC Advice
« Reply #13 on: 14 August 2008, 21:27:16 »
It's got about as far as it can:
AXMA3000FKT4C Mobile Athlon Barton XP, Overclocked (slightly) to 2418MHz Fastest available XP chip supported by my board (266FSB)
1GB 266-DDR (max for board)
ATI Radeon 9800 PRO 128MB
DVDrw
CDrw
Netgear Wireless PCI adaptor
she's not a bad old girl and been steadily upgraded over the years (and taught me a lot) but board is hloding back now and so is my empty wallet ;)
« Last Edit: 14 August 2008, 21:27:48 by herefordelite »
Re: PC Advice
« Reply #14 on: 14 August 2008, 21:29:56 »
DVDrw
CDrw
Trouble is, its all ol technology, so the next step means something more drastic....
