Sending a Fax Overseas - Paperless.
Started by zirk, 26 April 2018, 16:59:07
zirk
Need to send a Fax Overseas, about 2 Pages, Dont Ask!, and no, they have PC and WiFi but dont accept Electronic Documents so its  Phone and Fax Machine only.
There used to be all sorts easy ways, email to Fax, WinFax, blah blah, but all seem to be subscription based these days.
Any good ones out there?, Free would be good from the PC or Phone App, I can probably sort out the International Call Rate by going through a VOIP Service although Im not convinced a Fax will work, ie, VOIP quality etc.
Ta.
Lizzie Zoom
Have you a printer with scan?
If you have I would scan and then send attachment with email ;)
Is that classed as "electronic"? ???
zirk
Quote from: Lizzie Zoom on 26 April 2018, 17:16:49
Thats classed as Electronic Delivery, they will only accept Paper or Fax Documents.
Lizzie Zoom
Quote from: zirk on 26 April 2018, 17:31:22
Ah, right.  Wasn't sure.  Isn't that old fashioned!  I always think of faxes as by electronic means, but I suppose rules are rules. :D ;)
zirk
Quote from: Lizzie Zoom on 26 April 2018, 17:47:54
Well Fax is by its nature a Electronic Document, but Im guessing its stood its test in time and is still considered and accepted as a Legal Document.
No doubt someone will tell me otherwise.
Quote from: zirk on 26 April 2018, 18:11:59
Don't you know anyone that works in an office that could send them for you?
As I use Asterisk, I have a Hylafax server I can "print to" and it will go out via the standard routing methods (invariably VoIP).
Despite the warnings otherwise, it works first time, every time for me.
My printer also has a fax, but can't remember last time I used that. Again, its plugged into a box that converts it to VoIP, goes through Asterisk etc etc.
Where abouts overseas? If a cheap enough country, I can send it for you (assuming not confidential etc)
zirk
Quote from: TheBoy on 26 April 2018, 18:22:52
Brussels and or Luxembourg, it is confidential but not worried too much about the contents, problem I have (only just found this out) is the Source Telephone No. needs to verified (or Traceable) back to me apparently.
But thanks for your kind offer.  :y
Going to pop in my Local Bank tomorrow and try and persuade them to do it, about time they did something for me.  :-\
Quote from: zirk on 26 April 2018, 19:36:32
You have a personal land line at your bank? That's fantastic service.   :y
zirk
Quote from: STEMO on 26 April 2018, 19:38:01
I know what your thinking, they said it can also come from a Professional Service Co, ie Bank, Solicitors, Emabassy etc, as they can confirm my Identity.  ;)
redelitev6
Fax machine ? i thought the last one went down with the Titanic  ;)
I have a small fax/phone machine in my attic that you can have if you need to do this regularly Zirk.
Mister Rog
I kinda miss faxes. You sort of knew where you were. Stick in machine, press "send" and you could call and say "have you got it". Nice and easy, no scanning, no email configuration, bad connections, balh blah.
But before that there was telex . . . . . oh no. Effin aweful
"The desire to be a politician should bar you for life from ever becoming one." Billy Connolly
