Zafira 1.4 Turbo petrol - Shed or not?
Started by Kevin Wood, 21 May 2018, 22:47:10
My brother is considering buying one. 2015 model with 30k on the clock IIRC.
Any horror stories? Anything to look out for?
It's got climate control, so hopefully not fitted with the incendiary fan resistor.
It's a bog standard Vauxhall, nothing different to any other bog standard Vauxhall. And it won't self combust unless you put Chinese parts in it.
I wanted one but out of budget as only put auto to 1.4 in 2015 ish, so I have 2.0 diesel.
Research suggested though 1.4 bit underpowered and needs high revs all the time, fine for pottering around town. But if he does motorway stints i would go for the diese.
It's 165bph, even in auto trim my Zaf does not disgrace itself. At no time does it feel under powered, easily zips up to 90 without breaking sweat.
BazaJT
I think this is the problem these days as manufacturers strive to claim ever better fuel economy and lower emissions they put ever smaller[albeit turbo'd]engines into ever bigger vehicles,so you have to thrash the nuts off them to actually go anywhere.
Quote from: tunnie on 21 May 2018, 23:35:55
It does indeed do pottering around town mainly, so a tractor is not going to cut it.
I think it'll probably do the job nicely.
tigers_gonads
Have a word with Mr Fuse about the engine because iirc, his lovely lady has the same donkey in there Mokka.
As for the rest, its just a zafira  :-\
Its a good little engine but, the Zaf C is a shed load heavier (1700kg kerb weight) than a Mokka (1400kg)  :y
The 1.6 turbo petrol would be a better fit.
Quote from: Fuse 19 on 22 May 2018, 12:16:44
I questioned this, sales bod informed me 1.4 Turbo had more power  ???
Quote from: tunnie on 22 May 2018, 20:59:16
A 1.4T has more power than a 1.6T?
Quote from: STEMO on 22 May 2018, 21:13:52
Well according to some sales guy at my local dealer, he said 1.4T had more power than 1.6T  :-\
He did also inform me auto diesel Zaf Tourers were rare  ::)
Can you get a 1.6 turbo? I haven't come across any.
Quote from: STEMO on 22 May 2018, 21:16:21
Not in the Zafira Tourer, usually see them in Astra type, Mokka etc.  :y
Quote from: tunnie on 22 May 2018, 21:16:56
Thought not, only ones I've seen are 1.4T and 1.8i.
