A year with the big black pussy
Started by TheBoy, 22 May 2018, 17:57:49
Well, well over 13 months now.
It remains a comfortable mile cruncher, with a decent turn of speed.
I'd say on average, I get low 30s mpg. I've had the occasional high 30s from a tank, and the occasional high 20s as well.
Failures have included:
Both front CDL motors
Front lower front wishbone arm bushes, replaced with polys
A single bonnet strut
A touchscreen display (might have been my fault ;D)
A failed NSR wheel bearing...   ...twice
A failed headlight washer extender thing (probably the shit ECP screenwash that froze)
In addition, its had:
2 oil changes
Air filter change
Pollen filter change
2 front tyres
2 headlight bulbs
New number plate fixing tape ;D
I really love the seat coolers, the heated wheel, the rear blind, the sunroof, the memory seats both sides, the crappy massager (for my poor back), adaptive headlights and cornering leds, the phone and ipod integration, and the fact the DAB holds onto a signal bloody well. It seems I'm lucky in that the Jag Voice works perfectly for me in default (untrained) mode, because that is a joy to use.
The annoyances include the fact the interior mirror isn't on memory, the clock wont set itself, the touchscreen is shite. Its also a bit long/wide for city centre stuff, particularly city centre carparks.
Running costs most definitely higher than an LPG'd Omega, probably on par with a non LPG'd V6
Auto Addict
What is it with clocks, mine doesn't reset itself either  >:(
I like red cars
BazaJT
Hell fire!! is it really 13mths ago you got it? Where the heck does the time go?
Quote from: Auto Addict on 22 May 2018, 18:02:32
Both our Vauxhall's do  :P
I thought Jeremy Corbyn had joined and started a thread.  :o
Quote from: STEMO on 22 May 2018, 18:53:58
You're hanging around that dodgy Opti fella too much ;D
Glad you like it  :y
Winning the battle with forums for DIY?
I'm keeping an eye out on XF-S, but so far the 3.2 does around 5-7k per year so far. Done very little to it since last summer, apart from air-con regas and finally replaced rear number plate. Oh replaced exhaust rubbers as they had split, thats it! This summer needs oil and filters, but so far so good.
These big 6 pot Jags are not brilliant on fuel it appears, I've given up resetting 3.2 fuel use. Too depressing! But it's appears to have stabilised to around 23mpg over last 6 months.
Will be interesting to see what car options I get with my new role
Quote from: Fuse 19 on 22 May 2018, 21:00:51
You've only just got the XF?
Viral_Jim
Quote from: TheBoy on 22 May 2018, 17:57:49
Touchscreen excluded (you clutz!) that does seem like quite a list. Compared to the ovlov at least (12m, 3 days and 35k onto ownership), which has wanted for nothing other than oil, filters, headlight bulbs, tyres and wheel alignment.
Do you think it's down to build quality, driving style, complexity or luck?
Quote from: jimmy944 on 22 May 2018, 22:20:07
Bonnet strut will be an age thing, wishbone bushes mileage (not seen a car type which does not suffer here), CDLs appears to be a weakness in the earlier cars.
Wheel bearing is luck.
Quote from: tunnie on 22 May 2018, 21:01:22
Discussion on-going, the XFD will probably stay, the Mokka go and my selected work vehicle added to the fleet.
Gaffers
I seem to remember that the XF I used to have had a memory rear-view mirror.  Which trim level is it?
Quote from: Gaffers on 23 May 2018, 09:03:37
Portfolio
None of the XFs I looked at had it either.
A big fat hefty tax bill ;D
