Removing a seized circlip
Started by Lazydocker, 23 May 2018, 15:28:29
Changing a front wheel bearing on a 206 and the circlip is well and truly stuck in the groove... Any hot tips for removing it?
A lot of swearing followed by losing an eye.
(No good tips - I broke several drifts trying to get stuck circlips out of the propshaft UJs when disassembling the Jag.. managed not to lose an eye, though)
henryd
Quote from: Lazydocker on 23 May 2018, 15:28:29
I use a die grinder and grind a groove in the hub where the join in the clip is so a screwdriver can get behind the clip,they are a pain in the as on peugeots :-\
other rides
I can get a grip on it but it just won't budge... Starting to get the hump now! ::)
Gaffers
Can you get a drill bit to it, cut it in half?
Soak it over night. Appreciate it's not a quick solution, but be less stressful than breaking it :y
Quote from: Doctor Gollum on 23 May 2018, 15:55:41
What, the car? In the sea? Following a departure from the top of beachy head?  :y
Actually, I was thinking that breaking it might be a good option, as long as you can get more circlips, but a bit of plus gas might be worth a try.
tigers_gonads
Quote from: Kevin Wood on 23 May 2018, 17:06:57
Yes  :y
A good squirt of plus gas.
Leave for a bit.
Give it a good tap all around the clip with hammer then oil it again.
Go back later when oil has worked its way between the clip and grove and bobs your auntie  :y
Been working it in all suggested ways... Will let it soak overnight and if it doesn't free off this time I'll heat it up ::)
Bigron
We are all allowed one silly suggestion, so here's mine!
Put a pointed tool/bit in a hammer drill and try to hammer it free, operating on the open end of the circlip to try to push it around.
If that gets it moving - job done?  :y
Ron.
Beachy Head is a good shout ::) but I was thinking about limiting anger damage to the hub carrier ;)
Quote from: Doctor Gollum on 23 May 2018, 21:58:15
May be too late  :-X ::)
But have you lost an eye yet? ;)
I got the (much smaller) circlips moving by levering one end out and then using a screwdriver to 'walk' the rest of it out far enough that it could come flying out like some kind of tiny un-guided missile.. (and then we had to weld bolts on to the bearings to get those out ;D)
Quote from: aaronjb on 24 May 2018, 08:46:36
So they didn't build the suspension to fall apart! Shame about the bodywork, really. ;D
The bits that were basically holdovers from the 1960s were built like a tank.. the bodywork designed in the 1980s was made out of tissue paper and good intentions ;D
