Author Topic: possible aircon problem volvo??  (Read 7458 times)
mathewst
  • Split, Croatia
    • v40
« on: 02 June 2018, 12:45:29 »
Got a new car recently (couldn't find a decent omega so bought a smaller volvo v40)
Car is in nice condition.
Engine is 1.9d 85kw.
But what bugs me is this.
Car has aircon and it cools fine but works strange (at least I think it works strange).
When you put the aircon on it doesn't drop the revs as every other car I've driven but it does so every 20 to 30 seconds
You can hear the revs drop as like the compressor engages and disengages every now and then.
Maybe it is designed to be like this I have no idea but if it is not what could be the problem here.
I haven't driven it to any garage.
My mechanic who serviced the last car says he won't work on volvo so have to find someone who knows what he is doing.
Anyone with any knowledge on this, advice would be appreciated.
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
Re: possible aircon problem volvo??
« Reply #1 on: 02 June 2018, 12:58:19 »
That's the  compressor clutch cutting in and out,  it's working correctly.
Hoof'land storeman.
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
« Reply #2 on: 02 June 2018, 18:24:55 »
As BG says that’s how they work but it may need a re-gas if it’s cycling too often
other rides
mathewst
  • Split, Croatia
    • v40
« Reply #3 on: 03 June 2018, 22:17:10 »
Thanks for the info.
Although not sure do I need to know now cause the belt snaped today    >:( >:( >:(.
As... who sold the car said he changed it two weeks ago and now it snapped.
Cant wait for tomorrow to call him.
  • Online Online
« Reply #4 on: 04 June 2018, 01:09:10 »
It won't help, but I did tell you to buy the Vectra... ::)
Private sale or dealer? Hopefully the latter as it will give you some comeback :-\
mathewst
  • Split, Croatia
    • v40
« Reply #5 on: 04 June 2018, 18:46:54 »
Well talked to the mechanic today who picked up the car.
Not good news.
It turns out the belt was ok and was indeed changed but the piston managed to rupture the engine block
and the engine is completely gone.
I asked the mechanic what can be the possible reason.
He said it can happen sometimes on heavy load usually.
Car was working around 2000 rpm and it wasn't even that loud when it happened. Car only did 137k miles.
Apparently it is renault engine and now I have to find a new one.
Just my luck
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #6 on: 04 June 2018, 18:59:06 »
so are you getting a refund ?
mathewst
  • Split, Croatia
    • v40
« Reply #7 on: 04 June 2018, 19:21:00 »
Will contact the dealer responsible for selling the car tomorrow and hear what he has to say.
I would like for someone to clarify what can be the possible reason for engine disintegraton.
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #8 on: 04 June 2018, 20:28:24 »
it's odd to happen at 2k revs
hydrolock ? where you driving through a river at the time  ;D
or has the coolant all gone (H.G fail hydrolock)
big end spun a bearing  or small end seized
lots of reasons
  • Online Online
« Reply #9 on: 04 June 2018, 21:20:31 »
Have done that to a banana engined Transhit... That had no oil in it and you could feel the crank knock through the seat :D
We knew it was low, but when first started, it was fine, and we only drove it in order to get to the site that some plum had moved the oil to... Only a mile away :-X
