Author Topic: coolant leak  (Read 9061 times)
Omega 37
  • Northampton
    • CD 2.2, HP Firenza & TR6
coolant leak
« on: 04 August 2018, 20:43:04 »
I have a coolant leak from a black plastic unit with 3 smallish 20MM sort of size pipes going into it. Its located next to the servo so difficult to see at the back of the engine.
Anyone know whats its called? or where to buy? cheers
Omega 37
  • Northampton
Re: coolant leak
« Reply #1 on: 04 August 2018, 21:08:33 »
its a coolant control valve. 22001 seems to be the part number
Carfix
  • Malmesbury, Wiltshire
    • 1997 & 1998 Omega Elites
Re: coolant leak
« Reply #2 on: 04 August 2018, 21:51:49 »
Probably the HBV (heater bypass valve).
Do a search on this forum and you will find plenty of information (and photos) on it.
Bigron
  • Witham, Essex
    • Omega 2.6 V6 Auto '51 Reg
Re: coolant leak
« Reply #3 on: 04 August 2018, 21:59:34 »
Along with your purchase of the HBV, make sure you buy a large box of Elastoplast! :(
Ron.
Omega 37
  • Northampton
Re: coolant leak
« Reply #4 on: 05 August 2018, 10:34:16 »
wondering if best from underneath? have access to s lift
Re: coolant leak
« Reply #5 on: 05 August 2018, 10:42:45 »
Read the guide ;)
From underneath you won't even see it, let alone reach it...
Omega 37
  • Northampton
Re: coolant leak
« Reply #6 on: 05 August 2018, 10:49:14 »
i could touch it and move it around but undoing the hoses  is another question:-\
BazaJT
  • SLady bitshorpe N.Lincs.
    • Omega 3 litre Elite
Re: coolant leak
« Reply #7 on: 05 August 2018, 13:11:00 »
Never had a 2.2 so don't know the layout,but surely this has to be easier to change from above even if it can be reached from below?
Re: coolant leak
« Reply #8 on: 05 August 2018, 13:26:56 »
2.2 is indeed even easier from the top compared to the V6  :y
flyer 0712
Re: coolant leak
« Reply #9 on: 06 August 2018, 16:02:45 »
2.2 are a bar steward because you need small steel hands to avoid getting cut to pieces...the original clips have a tongue on them and are hard to get at you can buy a special pair if clip removers that are a pair of pliers with a long cable attached which once you get them on the clip you can lock them in place and open the clip....
terry paget
  • Midsomer Norton Somerset
    • 3 Astras 2 Vectra
Re: coolant leak
« Reply #10 on: 06 August 2018, 19:55:55 »
I changed my first HBV on a 2.0 from below. I could see it very clearly, and managed to change it at arms's length. Later I changed one on a 2.2 from above, after removing the scuttle. Still not easy. I am impressed how tough 20 year hoses are.
Re: coolant leak
« Reply #11 on: 07 August 2018, 00:37:16 »
Have never removed a scuttle to change one. Ever.
polilara
  • Finland
    • 2.6 Y26SE Elegance 2001
Re: coolant leak
« Reply #12 on: 07 August 2018, 16:36:26 »
V6 or 2.2 or both? In V6 I succeeded only after having removed the scuttle, difficult for me anyway.
Re: coolant leak
« Reply #13 on: 07 August 2018, 18:15:01 »
Both, but left hand drive different as HBV is tucked in the corner of the pollen filter cavity ;)
polilara
  • Finland
Re: coolant leak
« Reply #14 on: 08 August 2018, 13:23:08 »
OK, thanks, that can explain...
Page created in 0.072 seconds with 14 queries.
