Author Topic: AVG Free error - "bin file is missing"  (Read 1294 times)
Bandit127
« on: 17 August 2008, 09:11:40 »
Hi All
AVG seem to be having a problem, it looks like yesterday's update is causing it to throw an error up . "A bin file is missing".
I tried uninstalling and reinstalling - no change.
AVG's website is hard to get to. Some Google surfing indicates they are on to it though.
In the meantime you can manually update with these files
http://free.grisoft.com/softw/80free/update/u7avi135781.bin
http://www.grisoft.cz/softw/80/update/u7iavi1616oo.bin
Save them to a folder.
In AVG, go Tools - Update from directory. Then tell AVG where the files are and it updates.
That worked for me.
Let me know if you have trouble getting these files and I will put copies on my website (if the Mods think it is OK to do so)
M16
  • Lancs
Re: AVG Free error - "bin file is missing"
« Reply #1 on: 17 August 2008, 09:22:25 »
Cheers for that mate
« Reply #2 on: 17 August 2008, 09:26:56 »
Not the first time this has happened iirc...  ...I tend to stay away from AVG now - just a confidence thing.
Still, not as bad as VMWare with their latest update to ESX server - timebombed!  And just before the timebomb went off, I nearly moved OOF to ESX.  And ESX is a market leading, datacentre level virtualisation software for mission critical apps!
waspy
« Reply #3 on: 17 August 2008, 09:54:00 »
Thanks for that. Did what you said & all sorted  :y
Dodger
  • Here in the sunny south!
  • I taught I saw a puddytat!!
« Reply #4 on: 17 August 2008, 11:31:10 »
Hi gang, had the same error first thing this morning, but had to go out, so no time to investigate.
Have just switched on, (5 min ago) and now AVG seems to be OK. Haven't done anything this end, so assume AVG have sorted the problem their end.
At 08:30 this morning, had the .bin file missing. At 11:20 all is OK having just done an automatic update check.
May not need to worry now lads... :y
Dodger
I always knew I'd inherit an estate, but I never thought this would be it!
« Reply #5 on: 17 August 2008, 14:50:45 »
Yup, todays update fixes it, may need to force an update though.
Crazydad
  • Germany
    • 2.5 V6 facelift
« Reply #6 on: 17 August 2008, 14:53:00 »
You beat me to it Jimbob, The new update sorts all problems :y :y
Edit: I didnt write that  LMAO ;D ;D ;D
« Last Edit: 17 August 2008, 14:53:53 by Crazydad »
« Reply #7 on: 17 August 2008, 19:04:56 »
You beat me to it 'Mr Farty Bum-Whistle', The new update sorts all problems :y :y
Glad the word filter is still causing amusement!  ;D
