FOR SALE - Various Genuine Parts for Facelift Omega
Started by Ironingboard, 26 August 2018, 23:19:39
Ironingboard
Hi I still have the following list of bits for sale.
New Genuine Vauxhall Parts
1x Rear suspension arm, front top rubber damper (goes above the large donut bush on the rear suspension arm)            Part No. 90447991      £3
4x Front Shock absorber Nuts and Bolts   (For a 2.0 Litre I thinkM12x1.5x55)   Part No. 11096171   £4
Front Engine Bay Fuel Pipes retaining clip   (fuel pipe to heater hose)   Part No. 90467190      £2
2x Front Anti-roll bar bushes         Part No. 90445625      £8
1x Front air Throttle seal             Part No. 90512145      £2
Rear Passenger Ashtray            Part No. 90363769      £5
6x Rear backing plate bolts         Part No. 11092671      £6
1x Rear flange securing nut         Part No. 90075162      £1
1x exhaust manifold to block gasket multilayer type   Part No. 24416110   £10
3x door card folding storage rubber dampers   Part No. 9196804      £1
6x stud and 7x nuts for securing exhaust manifold to bloc    Part No. (Studs) 90106924 (nuts) 90502418      £10
3x nuts used to secure rear control arm    Part No. 90538058(old part no.)/13136972   £3
1x Copper sump washer      Part No. 11023582      £1
4x O-ring seals    Part No. 90467275                  £2
2x nuts used to secure exhaust manifold to catalytic converter drop down pipe   Part No. 90570845
£4
3x plastic engine breather retaining bolt to induction   Part No. 11096061   £2
1x seal ring throttle valve body to induction manifold   Part No. 90412566      £1
2x rear shock absorber bumper stops (2-piece assembly)   Part No. 90468006   £10
4x Rear Shoe Pins       Part no. 24420393         £4
2x Rear suspension damper block to crossmember bolts      Part No. 11094161   £2
2x Trim clips Part No. 2208843      £1
New OEM Parts
1x lemforder/boge rear donut bush   lemforder 1606301 (vx Part No. 90447156)   £20
1x rear wheel bearing    Part No. 90510542               £20
Used OE and genuine Parts – all working
2x front drop links   (Removed to spray paint metal but never refitted, almost new)      £15
1x Set of 3.0 or 2.5 BERU Spark Plugs Leads         £20
1x aux water pump    Part No. 90448286         £20
2x Trim retaining clip for boot trim opening     Part No. 90457577      £4
