Author Topic: Carbon Fibre shower tray  (Read 965 times)
Martin_1962
« on: 16 August 2008, 19:53:26 »
Thanks to Debs I now have a small collection of reinforcing materials
Black is carbon fibre yellow not sure but I had trouble cutting it and white fibre glass
Used the carbon fibre to reinforce the caravan shower tray which had two rips and a punched out drain on it.
Glued it together first then today I covered it - I'll take a picture tomorrow when I cut out the drain
Re: Carbon Fibre shower tray
« Reply #1 on: 16 August 2008, 19:56:42 »
Those gel coat shower trays are shite.....total and utter shite!
Trouble is, on a pikey wagon, what choice do you have!
« Last Edit: 16 August 2008, 19:56:51 by Mark »
« Reply #2 on: 16 August 2008, 19:56:58 »
Will it melt when it gets (very) hot ::)
Debs.
« Reply #3 on: 16 August 2008, 20:09:51 »
The Yellow bi-directional cloth is Aramid (Kevlar) Martin.....it`s very high-modulus, so doesn`t 'shear' well with normal-scissors; to cut it from the roll I use a special set of Kevlar shears (with diamond-dust on the shearing-faces).....ordinary scissors will work on Kevlar if you take short/slow 'hacks' and keep the cutting zone very near-to the pivot.
Kevlar is excellent for use in repairs where concentrations of stress is present from previous laminar damage. :y
The black carbon cloth is strong and stiff; so might stop that damage from re-occuring. ;)
Martin_1962
« Reply #4 on: 16 August 2008, 22:07:38 »
Right as far as I can acertain (sp) the tray is ABS and varies between 1mm and 2mm in thickness. it relies on the floor for strength. The glue I used is a general purpose solvent glue loved by modellers, this is a heavy duty version which also does ABS and melts the plastic.
When removing the tray it ripped in two places, now I glued (solvent welded) the two splits then the following evening used PP gelcoat filler over them - I also reattached the punched out part of the tray with the same technique.
This afternoon I covered the whole stand on area and the sides with a layer of carbon fibre with a second layer of kevlar over the drain hole.
I also was able to drill out the hole but I just did a couple to see how easy it is.
Tomorrow I drill out the whole drain hole and gelcoat the rest of the rips, I will also sand down the current repairs first.
The gelcoat around the drain is a bit difficutl to sand but I will do it first.
I hope to refit the tray next weekend as I need to add more support wood, add a drain for the inside of the toilet as spilt flush water cannot be drained (the poo and wee goes into a cartridge), I also need to repair a crack in the bowl unit.
The toilet is screwed through the tray and into the floor, this prevented me from using more than 1mm of support except over the hole.
When complete I will push GRP paste up around the drain to definately stop any more punch throughs on the drain.
Martin_1962
« Reply #5 on: 17 August 2008, 20:43:07 »
This is a view of the underside
Hole before drilling - the filler is covered by the drain
Side of the tray
Hole after drilling
« Last Edit: 17 August 2008, 20:48:26 by Martin_1962 »
Debs.
« Reply #6 on: 17 August 2008, 21:56:37 »
 :y Very tidy work indeed Martin: the 'laminatrix' approves! ;)
Martin_1962
« Reply #7 on: 17 August 2008, 23:09:53 »
Thanks Debs and partially refitted earlier with Sikaflex sealer
Lots gunged around the edges to seal it
And the drain looks fine :y
