Question about extensions
Started by tunnie, 06 September 2018, 14:22:28
Our house is detached, therefore I can extend 4m back from the property within permitted development.
What happens if it's just outside that? say 4.1 metres? As to extend and match the garage wall line, which is what I want to do, it is fractionally longer than 4m.
Would that need planning permission?
Builder said he's only had one inspector measure and that was due to neighbour of the extension complaining.
Finally had a decent builder around and quote is within budget, so it's plan B for us if we cannot move.
Quote from: tunnie on 06 September 2018, 14:22:28
Yes. Otherwise you're just taking your chances .. maybe it will be fine, maybe nobody will ever ask, but if they do you could find yourself having to knock it all down.. and if it's spotted when you come to sell the house, you might find nobody wants to buy it because proper planning wasn't in place and they don't want to be faced with having to knock it down.
deviator
Or build it to the 4m limit and extend that in a couple months time?  ::)
Quote from: aaronjb on 06 September 2018, 14:33:12
Thanks  :y
Also do they measure from the outside wall I guess? It's really annoying as its just a few cm's in it.
You could add a chamfer to the corner of the garage wall to balance it...
GastronomicKleptomaniac
Build it to 4.1m. Then purchase a custom measuring tape that is 2.5% out. Then helpfully lend this to anyone that wants to measure...
You will also probably find that the original plan was deliberately and carefully measured to create just such an issue thereby removing the temptation to extend... Especially if the original estate builders were the land owners...
I basically want to do this:
http://i264.photobucket.com/albums/ii177/tunnie_84/Extension.png
House, Garage, Conservatory.
So building line remains to current garage, not house. But where the house ends and the garage ends, is just fraction over 4.0m.
I'd then have large kitchen/diner going into the current garage space. Luckily, the garage floor is lower than house, so can be insulated without issue.
If you simultaneously extend the garage to the front building line, then you can keep the garage as well  :y
Quote from: Doctor Gollum on 06 September 2018, 15:33:40
Possible, but that would mean loss of 1 of my front parking bays. Also would push costs too high, already at the limits.
I'm prepared to take a huge loss on the garage and only have small storage area for tools.
Quote from: Doctor Gollum on 06 September 2018, 15:47:33
Buyers may not...
Given my house is only one in the close with a garage, won't make any real difference. In fact out of the 25 or so modern house builds around me, I'm the only one with a garage.
It won't sell with full garage currently in place anyway, so clearly not that wanted.
Varche
It is only a thought but if you are only talking about an extra 10 cm to square it up, why not apply for planning permission. Would it cost much more to do so? I
Rods2
Ask your local planning department for advice as IME they are normally very approachable and helpful. The minimum/maximum building line may well be the edge of your garage as that is the edge of the current building. Is the area/height of the extension and the distance from any boundary within building regs. or will you need planning permission anyway?
Quote from: Varche on 06 September 2018, 16:36:13
There is cost time and designs and such that have to be submitted, without it saves a lot of faff.
Quote from: Rods2 on 06 September 2018, 16:44:30
Should not need permission if it was sub 4m or 4m exactly, distance from boundary is fine.
Will contact planning dept  :y
