Impact Wrench
Started by Sir Tigger KC, 08 September 2018, 12:12:47
The cambelt is due on my Mondeo and I'm considering doing it myself.  ::)  :-\  There are a few good guides and it looks reasonably straight forward, although the reality will probably be very different!  ::)  ;D
Due to space limitations, it's recommended to have a decent impact wrench, so I'm looking for recommendations!  :)
TIA!  :y
Quote from: Sir Tigger QC on 08 September 2018, 12:12:47
TIA!  :y
Is this wise? :)
Not at all, but I've never been noted for my wisdom.  ;D
Quote from: Sir Tigger QC on 08 September 2018, 12:22:28
Something we share in common. :)
If I do it, I fully expect it to be a complete PITA, and I'll spend the entire time doing it regretting not taking it to the garage.  ;D
It'll be about 400 notes for the cambelt kit, water pump, aux belt and tensioner, supplied, fitted and VAT at a local garage.  I can get the parts for less than 150 or less than 200 for genuine ford bits.  Tempting.  :)
Then with the money saved I can buy an Impact wrench which I'll always have.  :y
Quote from: Sir Tigger QC on 08 September 2018, 13:31:17
At least you'll have the beemer to fall back on when you break the mondeo. And think of the laugh you'll give the lads at the garage when they have to recover it to finish the job.
Quote from: STEMO on 08 September 2018, 13:34:30
Yes and Yes.  ;D
omegod
If going cordless you'll need to spend a few hundred on one to get a crank bolt off but clarkes corded one is nearer £50 and is reputed to be a big hitter
Optimistic?
His BMW is older than Moses. One of the last Victorian German cars still running. ;)
Of course, the mighty Signum is above anything as crude as a belt. :)
Quote from: Field Marshal Dr. Opti on 08 September 2018, 17:24:44
Optimistic?
And it runs very well too thank you!  :y
Quote from: omegod on 08 September 2018, 16:44:20
Someone said on the TalkFord forum that they couldn't get the crank bolt off with a cordless Clarke impact wrench that they had bought for the job.  ::)
Hence my request for recommendations, but instead I get Lord Opti and Uncle STEMO weighing in with the piss take!  ::)
I guess the day care centre is closed on a Saturday!  :-\                                                          ;D ;D ;D
tigers_gonads
I bought one of these last year
https://www.ryobitools.com/products/details/18v-lithium-plus-impact-wrench-kit
Yes, its not cheap
Yes, you will have to buy the battery and a charger separate if you haven't got one.
But if your looking at replacing your battery power tools in the future, its worth it because one you have a charger and battery, you just need to buy the tool as and when.
Must say, its had some serious use (suspension / bearings ect) but its never failed to undo anything  :y
Also shop around because some shops really take the piss  :(
Quote from: Sir Tigger QC on 08 September 2018, 18:05:14
Noooooooo......that's me being helpful, you'd know about it if I was taking the piss.   ;D
Viral_Jim
Quote from: tigers_gonads on 08 September 2018, 18:13:30
Yes, its not cheap
On batteries, if going down this route, pick up a big (4.0ah plus) battery as the smaller 1-2ah ones limit the performance of these tools.
I bought my Makita drill a few years ago with the thought that any further cordless tools I bought would be body only Makitas.  :y
Then Makita went and changed their batteries!  >:(  ::)
